UNEVEN SUSPENSION
Old Oct 9, 2008 | 08:23 PM
dirtyharryhatch's Avatar
A Digital Frontier
Default UNEVEN SUSPENSION
so i did a lil research and from what i got the driver side of the EF is heavier therefore making that side lower but i just got function and form type 1s haven really driven the car but its such a big difference that im worried if the suspension will "settle" in as i was told anyone can help me out need some info or if someones been threw this and what i am going to expect
Old Oct 10, 2008 | 10:52 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: UNEVEN SUSPENSION (dirtyharryhatch)
Post pics. It shouldn't be 'THAT' off... in fact, you shouldn't see a difference...
Old Oct 10, 2008 | 11:32 AM
gator88's Avatar
Default Re: UNEVEN SUSPENSION (phoenix_iii)
I am curious too, except mr driver's side is the high side. By about a half inch. Owell it is in alignment, owned sinc enew so i know it wasnt wrecked, and it handles great so it only bothers me a little bit. I would like to make it closer to level if i just knew how.
Old Oct 10, 2008 | 11:52 AM
ammob16's Avatar
IYAAYAS
Default Re: UNEVEN SUSPENSION (gator88)
Mine does the lean. It was way worse with the stock suspension but its liveable with the Omni's.
Old Oct 10, 2008 | 12:01 PM
sgallagher's Avatar
Try loosening all your control arms to unload the bushings. Retighten all of them with the weight of the car on the arms to preload. May not be your problem but it should always be done anyways.
Also make sure your bushings are in good condition.
Bleakened
Feb 7, 2018 07:45 PM
suspendedHatch
Suspension & Brakes
Apr 18, 2006 09:27 PM
egb18c5
Suspension & Brakes
25
Dec 9, 2005 08:15 AM
Mr.E.G.
Suspension & Brakes
116
Nov 15, 2005 11:31 AM
TspEk9
Feb 1, 2004 01:10 PM
