OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!!
Old Oct 9, 2008 | 06:03 PM
redline870's Avatar
Default OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!!
any one whos got oem fog lights is gonna know my frustration with this one. when i turn on the fog lights on they only stay lit when the low beams are on. when i turn the high beams on, the fog lights go off. where i live theres tons of deer so i need the most lighting possible. is there any way to run both the fog lights and high beam without running a seperate switch?!?! is there a wire i can snip or a fuse to pull or something to stop them from turning off?
Old Oct 9, 2008 | 06:09 PM
DAP97SI's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (redline870)
I think that is the purpose of the fog lights, you are not supposed to use high beams on fog.
Old Oct 9, 2008 | 06:11 PM
redline870's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (DAP97SI)
they light up the sides of the road too which helps to see deer my main concern
Old Oct 9, 2008 | 06:47 PM
geebs's Avatar
I know in NY its illegal to have fog lights on while your high beams are on. You live in NY.. Obey the law.
Old Oct 9, 2008 | 07:21 PM
NOFX's Avatar
H-T White Ops
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">I know in NY its illegal to have fog lights on while your high beams are on. You live in NY.. Obey the law.</TD></TR></TABLE>
True.
I know there is a way around it on some cars, but the OP didn't mention which year his car is.
Old Oct 9, 2008 | 07:30 PM
mistik_DC4's Avatar
Dam it. I was gonna say hook it up to a switch. Well my dad has a camry with aftermarket foglights. When he turns on the headlights, the foglights turn on as well. Also, when the high beams are on, the foglights stay on as well. Ill check to see how the wires are hooked up as soon as I can. U can probably try aftermarket wire harness for the foglights and see if they work. Good luck with foglights.
Old Oct 9, 2008 | 07:34 PM
egsleepercivic's Avatar
where the fog light harness plugs into the underdash fuse box i believe there is a brown connector you need to move it to another spot on the fuse box, there is a place u can plug it in thats hot when ever the ign is on, there is a pic on h-t somewhere that tells u what to do, i have the pic somewhere but can't find it right now
someone will post a link, i'm gonna look and see what i can find
Old Oct 9, 2008 | 07:53 PM
Default Re: (egsleepercivic)
here you go
Old Oct 9, 2008 | 07:54 PM
Project S.A.M's Avatar
Are you refering to OEM fog lights in general or OEM fog lights for a specific car?... I just checked my 93' civic and the fog light stays on with high and low beam. Make sure all your connection is right especially if the installation involves the fuse box under the dash.
Old Oct 9, 2008 | 08:06 PM
redline870's Avatar
obey the laws? so what you mean to say is you never speed? i highly doubt that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
I know there is a way around it on some cars, but the OP didn't mention which year his car is.</TD></TR></TABLE>
1993 del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">where the fog light harness plugs into the underdash fuse box i believe there is a brown connector you need to move it to another spot on the fuse box, there is a place u can plug it in thats hot when ever the ign is on, there is a pic on h-t somewhere that tells u what to do, i have the pic somewhere but can't find it right now
someone will post a link, i'm gonna look and see what i can find </TD></TR></TABLE>
thanx for the pic, are you sure the connector is brown? can you double check that for me or possibly get a picture? thanx for ur response, at least this gives me an idea of where to start
Old Oct 9, 2008 | 08:15 PM
Bad Brian's Avatar
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Default Re: (redline870)
the connector, not the wire, IS brown and behind the fuse box. your harness should already be plugged into it.
there is a post here at H-T explaining how to swap it over to your parking lights' hot wire so that it works with parking, low or hi beams.
maybe it is in the section called LIGHTING, I do not remember. do a search.
Old Oct 9, 2008 | 08:25 PM
never having foglights, but by looking at the diagram, you should be able to move connector d to any other open slot a-e, excluding d, then u should be able to turn on the fog lights on whenever you want or only when the key is in and turned on
**E is for the radio **
Modified by egsleepercivic at 4:13 AM 10/10/2008
Old Oct 9, 2008 | 10:29 PM
994doorwife's Avatar
wow that's odd mine stay on when my lights come on. sorry good luck with it.
Old Oct 9, 2008 | 10:44 PM
NOFX's Avatar
H-T White Ops
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (994doorwife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994doorwife &raquo;</TD></TR><TR><TD CLASS="quote">wow that's odd mine stay on when my lights come on. sorry good luck with it.</TD></TR></TABLE>
I know for 6th gens there are two different interior harnesses. The updated harness makes the lights turn off when you turn your high beams on and visa versa. Older 6th gen ones kept them on.
Old Oct 9, 2008 | 11:45 PM
Frost7177's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (NOFX)
is that diagram the same for a 97 dx hatch?
Old Oct 10, 2008 | 05:45 AM
NOFX's Avatar
H-T White Ops
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (Frost7177)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost7177 &raquo;</TD></TR><TR><TD CLASS="quote">is that diagram the same for a 97 dx hatch?</TD></TR></TABLE>
There's a fuse thread linked in the FAQ that I made that has ''92-'95 Civics, '96-'00 Civics and del Sols too.
Old Oct 10, 2008 | 02:33 PM
herro.denmark's Avatar
I have never understood Americans and the love for fog lights. I just turn the low beams on and I have never had any issues with the fog. Is the fog much thicker in the America of USA?
Old Oct 10, 2008 | 02:47 PM
redline870's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (herro.denmark)
its not the fog im so concerned about, the fog lights help light the sides of the road to see the damn <U>deer</U>
Old Oct 10, 2008 | 02:53 PM
redline870's Avatar
so ive located the connector behind the fuse box. all the connectors are brown so that description didnt help to much. the connector plugs into the relay for the fog lights. so now what? which color wire on the connector is the hot one that i need to move to a different spot on the fuse block? ive done endless searches only to find out how to do it for a 99-00 civic si and its definately not the same for my car. anyone know what to do now?
Old Oct 10, 2008 | 02:57 PM
JDM_902's Avatar
Look at the diagram already posted in the thread, I put a set of oem fog on my car 2 weeks ago (1996 civic dx). I don't know where it would be if it's already plugged in somewhere but I plugged mine into C in opiton connectors.
Old Oct 10, 2008 | 03:06 PM
redline870's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (JDM_902)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_902 &raquo;</TD></TR><TR><TD CLASS="quote">Look at the diagram already posted in the thread, I put a set of oem fog on my car 2 weeks ago (1996 civic dx). I don't know where it would be if it's already plugged in somewhere but I plugged mine into C in opiton connectors.</TD></TR></TABLE>
i already know which spots on the fuse block are hot. i need to know which wire on the connector should be cut and plugged into one of these hot spots.
Old Oct 10, 2008 | 03:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline870 &raquo;</TD></TR><TR><TD CLASS="quote">
i already know which spots on the fuse block are hot. i need to know which wire on the connector should be cut and plugged into one of these hot spots.</TD></TR></TABLE>
none should be cut move connector d to another spot thats open, don't cut anything
Old Oct 10, 2008 | 04:49 PM
bpkmrtoes's Avatar
Default Re: OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!! (egsleepercivic)
none should be cut move connector d to another spot thats open, don't cut anything </TD></TR></TABLE>
yeah. There should be a plug already in one of those slots. move that plug to a hot spot.
Old Oct 10, 2008 | 05:02 PM
redline870's Avatar
there are 3 wires hooked into the fuse block 2 that are for my gauges and one red wire with a yellow connector but i dont know what its for
Modified by redline870 at 9:24 PM 10/10/2008
Old Oct 10, 2008 | 05:14 PM
then ur foglight are probably oem style and not actually oem, there is no telling how the person wired them up then
