Does the 01-ITR AC turn off under high throttle?
Old Jul 28, 2002 | 10:31 AM
madtypR's Avatar
Default Does the 01-ITR AC turn off under high throttle?
I've been reading about the GM cars and many of them turn their AC if the throttle is open more than 75%. I was wondering if the ITR does this because it would be a good idea seeing how our cars are a bit lacking in the torque dept. I have a hard time remembering to turn the AC on and off when tackling a technical piece of roadway.
Old Jul 28, 2002 | 10:32 AM
B2FiNiTY's Avatar
Default Re: Does the 01-ITR AC turn off under high throttle? (madtypR)
I've heard it's only a rumor...I really doubt it that it does turn off.
Old Jul 28, 2002 | 10:37 AM
madtypR's Avatar
Default Re: Does the 01-ITR AC turn off under high throttle? (B2FiNiTY)
I was thinking if it doesn't it would be difficult to cook up some circuitry to make it so.
Old Jul 28, 2002 | 10:46 AM
madtypR's Avatar
Default Re: Does the 01-ITR AC turn off under high throttle? (stephen c)
I'm thinking of monitoring the throttle position sensor and once it reads 75% or so having some circuitry tell the ECU to kill AC.
Old Jul 28, 2002 | 11:02 AM
Tweakmeister's Avatar
here's an idea...reach over and touch the button! .... seriously, I just turn off the ac if I know I'll be revving a bit. Having driven a '96 (redlining every chance I got) the ac compressor took quite a beating, and in the later years it will really thump and spurt and do weird things. Just turn it off for more spirited runs.
Tweakie says - this is like the american mentality vs. japanese or something.
Old Jul 28, 2002 | 11:12 AM
madtypR's Avatar
Default Re: Does the 01-ITR AC turn off under high throttle? (Tweakmeister)
Another reason I'm an electrical engineer and a car isn't yours until you've started swrewing with its wiring opening panels the say qualified service only.
Old Jul 28, 2002 | 12:18 PM
TypeR_853's Avatar
couldn't have said it better...
Old Jul 28, 2002 | 01:22 PM
Default Re: Does the 01-ITR AC turn off under high throttle? (George Knighton)
hahahaha
okay, I'm reaching over to the Helms. I'll get a switch that shuts off the AC when the rpm's hit say 5000rpm.
Old Jul 28, 2002 | 05:06 PM
JohnnyBoy's Avatar
I think it does have a WOT bypass. We saw it happen on the dyno during a run with the A/C on....was down a bunch of HP then bang! right back up to normal....I don't think I have the plot, but i'll look for it. If I remember correctly it bypassed in the higher end of the RPM.
[Modified by JohnnyBoy, 5:09 AM 7/29/2002]
Old Jul 28, 2002 | 05:12 PM
Def's Avatar
Def
Default Re: Does the 01-ITR AC turn off under high throttle? (JohnnyBoy)
My lowly Integra GS does not cycle the AC off at WOT. The car is so slow that it is REALLY obvious when it is on or not.
But you do realize that the AC compressor does not stay on continuously. It cycles on and off at a set interval so that the evaporator coil doesn't ice up.
JDMswagSerf
Jan 16, 2014 07:04 PM
NumberB
Jun 11, 2006 06:10 PM
See Are X
Apr 19, 2002 09:49 PM
