65mm throttle body help!
Old Oct 9, 2008 | 04:39 PM
crunchy_taco's Avatar
Default 65mm throttle body help!
OK i'm not sure what type of throttle body is on my car but the inside measured 65mm and the outer 73mm.
The only ID on the throttle body is a stamp with HAD.
Have a ghetto rigged intake on there, a stock ls airbox but it ripped so now I need a new intake. Which size intake should I get, 65mm?
Old Oct 9, 2008 | 09:15 PM
Default Re: 65mm throttle body help! (crunchy_taco)
Old Oct 10, 2008 | 02:28 PM
Bump
Thinkin about just using stock airbox and buying plastic piping from home depot, anyone do this before?
Old Oct 10, 2008 | 03:56 PM
slambedcivic's Avatar
type r throttle body if im not mistaking.
you can use a universal 3" intake.
Old Oct 10, 2008 | 06:58 PM
Default Re: 65mm throttle body help! (slambedcivic)
Type R is 62mm i believe.
Old Oct 11, 2008 | 06:11 PM
HdeucedeuceA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crunchy_taco &raquo;</TD></TR><TR><TD CLASS="quote">Type R is 62mm i believe.</TD></TR></TABLE>
right you are
Old Oct 13, 2008 | 08:54 AM
crx-b18c's Avatar
i using 3 inch with my 65mm trottle body
Old Oct 13, 2008 | 02:54 PM
Default Re: 65mm throttle body help! (crx-b18c)
Thank you think ima check out some cheap ebay piping.
chunkybs
Oct 20, 2007 11:56 AM
92sihbk
Sep 23, 2007 09:14 AM
EG5Boy
Dec 22, 2006 06:41 PM
Project_Civic
Apr 3, 2005 05:16 PM
ITR.#1446
Dec 4, 2003 06:10 PM
