painting carbon fiber
ok well i get a carbon hood that i would like to paint milano red . i would like to know if anyone knows how good will the paint hold on onto it . ?
cuz all the shops around me whould not paint carbon fiber parts .
From: somewhere in the d, mmm stake, mmm country fried stake
i thought you could just spray over carbon fiber...you just scuff it up enought to where the paint can bite...but ive never tried painting cf...hmmm good to know....
Painting carbon fiber is just like painting anything else that is already finished...
Scuff the panel and use an adhesion promotor. As long as you know that any waves or cracks or heavy scratches in the surface will show through on the new paint job unless they are fixed, you shouldn't have any problems at all.
If you want to PAINT carbon fiber correctly. you need to prime the hood with a 2k urethane, or an epoxy primer. Carbon fiber is porous and will suck up material, if you just paint directly over it you will most likely have fading, die back and color fade will most likely occur because the material is being inhaled by the c/f. You need to fill the pores first before you lay color.Prime it, and of course lay some sealer when you are painting. If you dont want it to [freak] up,i would definitely suggest you prime it first. wait a few days,sand it down and do it again.
Same goes for if you just want to reclear a carbon fiber hood, sand all the crap gelcoat or whatever it is off. Spray 3 coats of clear, let it dry for a couple days or so, unless youve baked the clear.and then sand down and reclear it again with 2 coats. And youll never have a problem. that is if your using a good clear that is worth a ****.You dont want to use a cheap clear with no u.v protectants cause youll just have to go back and do it again cause of fading and yellowing. I paint and reclear carbon fiber parts all the time at the paint shop and this method has not yet failed me in many many years. And parts that i did 4 years ago still look like the day they came out of the booth.
