5-lug brake question
Old Oct 9, 2008 | 04:17 PM
. a d a m's Avatar
Default 5-lug brake question
Just to start things off, I have a 97 EK with 5-lug.
My car needed new front pads, so I went and got some, and while putting them on, I ran into an issue. While trying to compress the piston back into the caliper, it wouldn't budge. No big deal right? I simply loosened the bleeder screw and the piston moved in easily. The same thing happened on the other side, did it over there too, and I knew that I had to bleed the brakes.
Enlisting the help of my dad, we bled the two front brakes. The brake pedal builds pressure fine while the car is off, but when I start it, the pedal falls nearly to the floor. So we try bleeding all of the brakes. Same thing. Try a one-man bleeder. Same thing. I am beginning to think something is wrong. But what? Is the master cylinder bad? Is it the brake booster? If so, do I buy the parts for an ITR or for a Civic?
Thanks a lot guys.
Old Oct 9, 2008 | 05:28 PM
7601chexplicit's Avatar
Default Re: 5-lug brake question (. a d a m)
make sure you have brake fluid. i also have itr suspension on my 00' SI, when i change the front brakes i use a c- clamp.
Old Oct 9, 2008 | 05:38 PM
. a d a m's Avatar
Default Re: 5-lug brake question (7601chexplicit)
Does anyone know which master cylinder I should buy based on the fact that I have 5-lug?
Old Oct 9, 2008 | 07:01 PM
Bob Dole!'s Avatar
An itr master cylinder. Did you bleed your rear brakes too?
Old Oct 9, 2008 | 07:33 PM
. a d a m's Avatar
Default Re: 5-lug brake question (Bob Dole!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! &raquo;</TD></TR><TR><TD CLASS="quote">An itr master cylinder. Did you bleed your rear brakes too?</TD></TR></TABLE>
Yes I did.
. a d a m
Suspension & Brakes
Oct 22, 2008 10:21 AM
4cylsturbo
Jun 20, 2006 06:37 AM
GSR95T
Jun 15, 2004 12:10 AM
VTEC
Dec 28, 2002 09:18 AM
