How To Remove your unwanted Trim paint
Old Oct 9, 2008 | 03:13 PM
pxsx's Avatar
Default How To Remove your unwanted Trim paint
Just recently bought an 89 CRX. The guy before me had painted the trim, and I didnt really like it.
This way for removing the unwanted trim paint is fairly easy. No messy products. No taking off the trim, so you dont risk breaking the plastic clips that hold it on.
Here is what youll need:
1. Some paking tape. I got mine at Rite-aid, its the rite aid brand. Im sure 3M will work too.
2. some type of tool to scrape off paint. Youll want a tool that is softer than the plastic trim, so it wont scratch it. What I found out works best is my cvs card. try it out.
3. some time.
heres what youll want to do:
1. clean the trims up.
2. put the tape on them, piece by piece, and press it down hard with the tool, or your hand.
3. rip the tape off.
It helps if you start chipping the paint off with a knife, or some sort of tool to get it started. after that, it should be easy. looks great too! Old school.
Old Oct 9, 2008 | 03:49 PM
92egvx's Avatar
Default Re: How To Remove your unwanted Trim paint (pxsx)
hahha...very nice...hahha
Old Oct 9, 2008 | 07:52 PM
JUSTCRX's Avatar
well, the guy before you did a crappy job. if he were to do a nice job, he'd have sanded down the trip before any paint was sprayed, and in that case, you'd have a hard time getting the paint off.
+2 for restoring your CRX to a factory level.
Old Oct 9, 2008 | 07:59 PM
D16SiHatch's Avatar
Default Re: How To Remove your unwanted Trim paint (JUSTCRX)
yea i was thinking that too. this really only applies to cheap paint jobs where little to no prep work was done. but props for bringing back the factory look
Old Oct 10, 2008 | 06:42 AM
pxsx's Avatar
yes that is true, a very cheap paint job was done. I think he probably went to macco and got that cheapest 1 spray over the whole car.
anyways, I love the factory look now.
Old Oct 10, 2008 | 09:11 AM
scottmog's Avatar
unpainted trim +1
stock crx +1
thx for actually fixing another idiots bad job
Old Oct 10, 2008 | 02:09 PM
zrickety's Avatar
Default Re: How To Remove your unwanted Trim paint (Mog)
how about plastic bits that are sanded and painted better? what would you guys recommend?
Old Oct 10, 2008 | 04:44 PM
IndySporty's Avatar
Default Re: How To Remove your unwanted Trim paint (zrickety)
I'd like to see if this works on the interior pieces that ricer idiots always paint white.
Old Oct 11, 2008 | 06:45 AM
pxsx's Avatar
give it a try.
for trim thats been sanded down and primed, you might just have to buy new trim. because if you do ever get the paint off with paint thinner, or aircraft grade paint stripper, the trim might not look good at all since it was sanded down.
HI91EFHB
15
Jan 11, 2010 04:29 AM
prjct92eh2
Paint and Body
Nov 3, 2008 07:13 AM
pxsx
Aug 2, 2008 06:30 AM
EK_Stunna
Feb 18, 2004 03:45 PM
