jdm b20b w p8r head intake mani question
Setup is simple at the moment. jdm b20b with the p8r head. I have a aftermarket manifold, not sure of the brand but its little bigger than a type r manifold. Got the car together and its very disappointing. Using a jdm r tranny with the 4.78 final. I figured this thing would move some. Is the manifold over kill for the b20 or something else wrong? By the way using a phearable.net basemap chip.
What i mean is the ls that was in the car prior felt stronger. I changed the motor and the intake manifold to this one. Was j ust wondering if it was overkill on a basically stock b20.
Then the answer is E: I don't know how well your butt is calibrated.
In all seriousness if you don't having anything objective to compare the two engines then it's hard for anyone to answer your concerns.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1rude2l »</TD></TR><TR><TD CLASS="quote">What i mean is the ls that was in the car prior felt stronger. I changed the motor and the intake manifold to this one. Was j ust wondering if it was overkill on a basically stock b20.</TD></TR></TABLE>
Without knowing the IM how is anyone supposed to answer this question?
There was a b18a in the car prior. Basically stock with the b18a manifold on it. I swapped in a b20b, and used a manifold similar to a skunk2. It could be a skunk2. I can't find a name on it nowhere. Just wondering if that big of a manifold is simply too much for a stock b20. The car felt stronger with the ls which had a hydro ls tranny. Now using the b20 i've switched to 98 spec type r tran. Just thought i was see a pretty decent gain with the b20 and the new tranny.
u have b20b which is a lower compression to the b18b which is maybe why u dont feel it as hard plus doesnt look it tuned, have the car tuned first and not just on a basemap
yes its a b20b with the p8r head. There is a write up i believe by bambam on here that explains all the b20's. By his write up the compression is 9.2:1. I believe pretty close to a b18a which is what was in the car prior. I know i need a tune. But really is it neccessary on a stock motor? I have future plans with a vtec head, different rods and pistons, and a good tune.
z06eateR
Jun 9, 2010 10:08 AM
