Transmission & Drivetrain Gearboxes, Differentials, Clutches
Mainshaft Thrust Clearance
Old Oct 9, 2008 | 12:10 PM
vinuneuro's Avatar
Default Mainshaft Thrust Clearance
Is there any way to set/check it without the mainshaft holder tool?
Old Oct 9, 2008 | 10:57 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Mainshaft Thrust Clearance (vinuneuro)
yes.
I've NEVER used the preload tool.
What tranny you messing with? I have a trick I learn when I shimmed my first D series. I've never followed the factory manual since.
Old Oct 9, 2008 | 11:02 PM
vinuneuro's Avatar
Default Re: Mainshaft Thrust Clearance (Mista Bone)
H22. If it'd help, I can post excerpts of the relevant helms section.
Old Oct 10, 2008 | 05:05 PM
Aquafina's Avatar
I don't use the holder either. I use a trick to check it. Probably the same as Bone since there aren't a whole lot of ways you can check it.
Old Oct 10, 2008 | 06:41 PM
Mista Bone's Avatar
D Tranny Guru
valve lash feeler gauges get used somewhere else?
Old Oct 10, 2008 | 06:46 PM
Aquafina's Avatar
Default Re: (Mista Bone)
I use them to shave sometimes when my electric needs to be charged.
Old Oct 10, 2008 | 06:51 PM
vinuneuro's Avatar
MistaBone does your method involve using a dial indicator at all? I understand you have to use feeler's to get find out the clearance between the mainshaft and the clutch and trans housings, to pick which shim to use. After that though, you need to use the dial indicator to actually find out the clearance..right?
wc4ohio
Apr 10, 2011 07:05 PM
dave@passenger
Welding / Fabrication
Apr 18, 2007 10:41 PM
idriveadelsol7
Apr 16, 2005 01:16 PM
