I'm rebuilding my ITR, I need some OEM part #
Old Oct 9, 2008 | 12:00 PM
Pondus's Avatar
Default I'm rebuilding my ITR, I need some OEM part #
As topic says, I'm doing a rebuild on my 99 ITR. I have taken off all the suspension components and had them blasted and powdercoated/painted to remove rust and to make them as good as new. In the process I removed the spindle/axle from the rear trailing arms, and f*?&¤d/had to drill out most of the Torx head bolts to get the parts separated. So, now I need new bolts, and also the locknut that goes on the inner end of the axle to get the parts joined together again. I have searched for these parts, but all the online stores only list the trailing arm as a complete unit, which is a bit more than I need. I already have a complete set of bolts for the rest of the suspension, these are the last ones I need to start bolting **** tohether again.
Anybody out there that know what parts I'm talking about and can help me out?
Old Oct 9, 2008 | 12:03 PM
Jackson's Avatar
Default Re: I'm rebuilding my ITR, I need some OEM part # (Pondus)
http://www.acuraoemparts.com/d...y.jsp
Old Oct 9, 2008 | 12:16 PM
Pondus's Avatar
Default Re: I'm rebuilding my ITR, I need some OEM part # (Jackson)
That's one of the online parts stores I've tried, for some reason I can't get the page loaded, maybe it's my slow *** connection causing trouble.
But are you sure they list these parts, all the ones I've searched (both Acura and Honda stores) only list complete trailing arms, as mentioned in my post.
Old Oct 9, 2008 | 12:24 PM
cxSHOE's Avatar
i dont believe they sell the spindles separately in the united states (they do in japan) so there is most likely no way to get the oem torx bolts atleaset through any US based parts store, hence not listed in the parts list.
when i did my 5 lug swap i remembe them just being a smooth rounded torx bolt. nothing special. im sure they have allen bolts or regular bolts at the hardware store with a 10 metal strength.
Old Oct 9, 2008 | 12:46 PM
B18CXr's Avatar
Can not procure directly from dealer
Old Oct 9, 2008 | 01:26 PM
len's Avatar
len
Default Re: (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Can not procure directly from dealer</TD></TR></TABLE>
Tis true, however I'm sure some creativity and ingenuity can fix the situation.
dartonh22
Honda S2000
Jul 8, 2008 10:44 AM
SpoogenJay
Nov 6, 2007 05:24 AM
92-h23a1
Jul 24, 2003 05:56 AM
TypeR 508
May 27, 2002 08:42 PM
