pro 1 cams b18c R
I have a JDM b18c R motor. 11.3 compression. .25 over bore honda oem piston. Skunk2 intake manifold. 98 spec headers. whale ***** intake. spoon n1 full exhaust. etc with the skunk2 pro1 cams and cam gears.
I have a p28 tuned from phearable at the moment and have had hell gettin the car to idle properly and jus have become frustrated. I have -50% at idle for my air fuel ratios to be at low 13s.
I am thinking about taking these cams out becuase I have a feeling my compression is not high enough. im looking into buyin tuner series cams.
or
buying hondata and tuning it.
I think these cams may be too big for my application
what do you guys think
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honkyb18c »</TD></TR><TR><TD CLASS="quote">
I think these cams may be too big for my application </TD></TR></TABLE>
yes, go with the tuner series cams. the pro1's need upgrade valve train to support
i had idle problems till i got pissed and set my throttle plate at 2,000rpm
Race car only for the win. I know some people idle like stock with them but i don't have the time and resources to spend at this time to make them idle like stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pellis90 »</TD></TR><TR><TD CLASS="quote">the cams are just too big ,,,,,, you need an upgraded valve train and alot of spring pressure,,,,,,,,,,,, long story short - switch cams
they still work good as hell, i spool and make power a hell of a lot sooner with these cams!
</TD></TR></TABLE>they still work good as hell, i spool and make power a hell of a lot sooner with these cams!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The sweed »</TD></TR><TR><TD CLASS="quote">It is important that you dial in those cams according to skunk 2´s spec sheet.. Otherwise you will have idle problems..</TD></TR></TABLE>
That is correct. It is critical that you have the car tuned properly for those cams to fully function accurately . Your idle should improve if the tune is done proper.
This has been discussed several times before. You have to degree them in, and then adjust them on the dyno to go from there. Between the 2 you can usually get a pretty good idle. These are awesome cams, but i personally went with the tuner1's with pro series springs and retainers. Much less hassle, but not as much midrange. Your compression is fine; you will even benefit from these cams with stock compression. Your tune and timing is what's holding you back right now. Hondata S300 and take it to a tuner! Then you will love them!!!!
I have dual valve springs and retainers. Yes I do agree that I need to dial the cams in correctly. I will be looking to degree them in the motor. Skunk2 reccomended a degreeing kit from xenonchron but i find it quite expensive. Im thinking that any degreeing kit should work. You guys agree?
I forgot to mention that I live in The Bahamas and we have NO dyno...No tuners that deal with chrome..hondata etc at all. Everything i get is from the states etc. This is why im kind of stuck. i know that people will tune over the net via sending logs etc. I just need to find the right people.
comments are welcome...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">i had idle problems till i got pissed and set my throttle plate at 2,000rpm
Race car only for the win. I know some people idle like stock with them but i don't have the time and resources to spend at this time to make them idle like stock. </TD></TR></TABLE>
race car only? dude, with a race car, dont you think youde want to take your time and make it right?
OP: i have a very similar setup. keep the pro 1s, get skunk2s springs and retainers and get your cams degreed, youll be happy with them
yea i have dual valve springs and retainers. Im going to degree them in and get some kind of tuning. I may jus go with chrome due to funds at the moment.
You guys know if any degree kit will work? they are all universal correct?
yes, you have dual valve springs STOCK. have you put something upgraded in there? you need to with the Pro1s. degree kits are universal to an extent. you just need to know how to use a dial indicator in conjunction with a degree wheel and some math.
Its all in the tune like every one is saying. Mine ran like crap untill i got the tune done on the s300 now i have ZERO problems. I also did not degree them but im sure if i were to now and go back to the dyno i could make more power. AWSOME cams tho mid to redline makes great power!!!
BTW: im on a 100% stock ITR but the cams and I/H/E
took my tuner 5 minutes to get em to idle, 900 -1000 rpms dead on with no loping.
my only issue is cold starts since i dont have an IACV or FITV since i have itb's. made a sweet power curve too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyLilCivic »</TD></TR><TR><TD CLASS="quote">BTW: im on a 100% stock ITR but the cams and I/H/E</TD></TR></TABLE>
Please tell me you're using correct VT..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">
Please tell me you're using correct VT..</TD></TR></TABLE>
yep all Pro series
yep all Pro series
yep all Pro series</TD></TR></TABLE>
then its not 100% stock. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">
then its not 100% stock. lol</TD></TR></TABLE>
WOW get a life, go make your post worth reading
Well, if what you said were true, then YES - you would be using stock VT...hence the reason I asked you. By this statement:
...what would deter us from thinking you were using stock valvetrain? Then you go off posting:
WOW get a life, go make your post worth reading</TD></TR></TABLE>
-Careful guy.....
-Careful guy.....
