Will EG coilovers work on an EF..?
https://honda-tech.com/zerothread?id=2377161
I have DC coilovers on my EF but you will need the front forks for EG/DC also so they can fit. Also for the rear, if you have 88 then u need to change your rear LCA. if you have 89-91 rear is all good and just bolt on. The EG/DC coilovers are also a little bit longer so your car might sit a bit higher. Mine doesn't, but just something to think about.
Chronicsinners
11
Jan 26, 2004 06:27 PM
