98 civic stereo wires?
the previous owner of my hatch, cut the wires away from the stock harness so now its just wires. i could have gotten a harness adapter but now im screwed. i just got a pioneer deck and i would like to see which wires go with which. im new at this stereo thing. thanks
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Ground Black
Dimmer n/a
Left Front (+) Blue
You can also get the SCOSCHE HA08RB Reverse Wiring Harness for 1998 & up Honda
http://www.sjgreatdeals.com/sisha08rb.html
This will allow you to reconnect the factory stereo.
do you have a picture of how to wire it up? thank you for the info already given. like i need the colors that match up with the OEM civic harness wires that were cut. i had found a site that told me which wire was twisted up with which but it was wrong and i blew a fuse in the attempt
Modified by ClutchVtech9 at 10:25 AM 10/9/2008
all the wires should be labeled on your pioneer deck. If you still dont know how to do it, get a buddy that is familiar with it to help you. Then have him show you. I would suggest like he said and buy the reverse harness that way you can buy the correct one and just plug it in to the harness instead of just wiring it directly to the pioneer.
mrredrocker
Oct 8, 2005 01:18 PM
DoctorGSR
Sep 2, 2004 01:36 PM
94
