Stumped on Smoke
Old Oct 8, 2008 | 09:00 PM
88CrxProjLS's Avatar
Default Stumped on Smoke
I have a 88 CRX (dx d15b2). I have read thread after thread about reasons as to why i may have smoke from the exhaust in my car. A whitish-blueish smoke comes from the exhaust after revving the engine and letting it idle, and also at any point in time when the engine is running at higher RPMs, anything higher thann oh say... doing about 30-35mph it smokes.
Okay, so i took a trip and threw a rod through my block when i first got the car, got a new d15b2 block off of a 89 Civic, the head gasket was in perfect condition, its torqued right. all of that good stuff ive read about. I also installedd a new radiator as to the old one had served its time, and installed a new water pump, all at the same time. Yet EVEN with this new block and crisp head gasket, im still getting smoke, sometimes worse than when i had the previous block. I installed a new PCV Valve, a new hose on it. Changed the oil. I dont have any leaks from my radiator, the fluid level hasnt changed any. I even installed a new thermostat when i put the new block on. Im just saying everything i can HOPINNGGG someone can figure this out. I installed a new timing belt, timed it myself, runs fine. New spark plugs/wires.
Occasionally, there is a black spattering from the exhaust, followed by a pop, which could and i believe is an exhaust leak from the manifold, where a nut is missing as to it only does it when slowing down on the interstate and off the gas.
I dont know what else to look at....
Could it be built up residue in my exhaust pipes?? Cat. Converter?? The exhaust pipes are pretttyy black and dirty looking... but i can only see but so far in there lol.
Frustrating...... people HATE beeing behind me.
Old Oct 8, 2008 | 09:12 PM
HOODLOVER's Avatar
Default Re: Stumped on Smoke (88CrxProjLS)
damn you should write a book..
how do you know the head gasket is in perfect condition on the new engine?
Old Oct 8, 2008 | 09:23 PM
TOO MUCH TORQUE's Avatar
head gasket could be in good condition but the block is probably not. Rings are fried..
Old Oct 8, 2008 | 09:28 PM
D16SiHatch's Avatar
Default Re: (TOO MUCH TORQUE)
i concur. this is a very likely possibility
Old Oct 8, 2008 | 09:33 PM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">head gasket could be in good condition but the block is probably not. Rings are fried..</TD></TR></TABLE>
who do you think you are... vin diesel? j/k
Old Oct 8, 2008 | 09:42 PM
sleepingciv's Avatar
Default Re: (HOODLOVER)
leaky valve seals, leaky rings,bad o2 sensor. id do a leak down test
racerx510
29
Feb 4, 2013 05:44 AM
Nooch
13
Dec 20, 2011 05:34 PM
Red-Rag-B18
Apr 23, 2010 09:33 AM
thelotusofchaos
Nov 6, 2009 05:21 PM
JasonHi
Oct 8, 2008 11:13 PM
