ZC Tranny install info needed
Old Oct 8, 2008 | 08:36 PM
vtec_head's Avatar
Default ZC Tranny install info needed
Hello, I was wondering if a 88 si clutch kit would fit a ZC Tranny? I was previously using my old si tranny for my ZC engine.
How many splines does the ZC tranny have? Does this matter since I have the exclusive half shaft for the ZC tranny?
Thanks in advance!
Old Oct 8, 2008 | 08:45 PM
ttm_sales's Avatar
It does matter, even if you have the intermediate shaft. What matters is the year of the ZC tranny also, I believe that they also came with either a 20 spline, or 21 spline Input shaft,
Old Oct 8, 2008 | 08:53 PM
vtec_head's Avatar
Default Re: (ttm_sales)
Okay, so the ZC in 88 came with the 21 spline like the Si tranny? And if that's the case I can use the 88 Si clutch kit?
Do you know how to identify the year of my ZC tranny? I guess I could also count the splines on the input shaft right?
thanks again!
Old Oct 9, 2008 | 04:40 AM
vtec_head's Avatar
Default Re: (vtec_head)
Can anyone else help with your input here? I assumed that all ZC transmissions were the same 88-91 ?
I just need to know if I can use my 88 si clutch kit or buy a new one that would fit the ZC tranny and if so what year model clutch kit?
thanks again!
Old Oct 9, 2008 | 07:03 AM
90efhatch's Avatar
no they are not all the same. I unfortunately got the 88 trans and had to use the smaller flywheel and clutch setup. You have to count the splines to see which one you have and use the clutch for that.
Do you have the trans already?
Old Oct 9, 2008 | 07:10 AM
vtec_head's Avatar
Default Re: (90efhatch)
Thanks man, yes I do have the ZC Tranny. I guess I just have to count the splines on the input shaft then and see. I know the 88 si tranny was the only one with 21 splines 89-91 years had 20 splines. 88 also had the smaller 200mm flywheel I believe...
Anyone else have any suggestions? Is there a clear and easy way to determine what year my ZC tranny is? Or what kind of year clutch fits in what ZC Tranny's?Unfortunately I haven't seen to much in depth info on ZC transmissions...
Old Oct 9, 2008 | 07:22 AM
kojack_0's Avatar
i would say upgrade to a 90-91 clutch, flywheel and pressure plate setup.
Old Oct 9, 2008 | 07:26 AM
vtec_head's Avatar
Default Re: (kojack_0)
why would the 88 si clutch kit I have not fit in this ZC tranny that I have if the splines match up?
Old Oct 9, 2008 | 07:37 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_head &raquo;</TD></TR><TR><TD CLASS="quote">why would the 88 si clutch kit I have not fit in this ZC tranny that I have if the splines match up?</TD></TR></TABLE>if the ZC transmission has 21 splines and you have 88 or 89 flywheel, you need the 88 CRX Si clutch kit - if it has 20 splines and you have 88-89 flywheel, you need the 89 CRX/Civic Si clutch kit - if it has 21 splines and you have 90-91 flywheel, you need 90-91 CRX/Civic pressure plate and 88 Accord disc - if it has 20 splines and you have 90-91 flywheel, you need 90-91 clutch kit
Old Oct 9, 2008 | 07:45 AM
vtec_head's Avatar
Default Re: (jlicrx)
Thanks man for clearing this up! May I ask where you got your sources for this information or is it just from your personal experience?
I'm confident you know chit though!
Old Oct 9, 2008 | 07:58 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_head &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man for clearing this up! May I ask where you got your sources for this information or is it just from your personal experience?
I'm confident you know chit though! </TD></TR></TABLE>personal experience from working with 88-91 CRX/Civic cars for the last 10 years and having performed over 40 DOHC ZC swaps
Gen4Si
Feb 21, 2005 03:34 AM
C-REX 88
Jan 19, 2005 08:06 AM
D-series ninja
Oct 1, 2004 06:10 PM
BioXide02
Dec 3, 2003 09:58 PM
91sifreak
11
Jan 18, 2002 07:22 AM
