ls/vtec problem
Old Oct 8, 2008 | 07:49 PM
jim9's Avatar
Default ls/vtec problem
Okay, my in-law just did a ls/vtec build.
b18a
bore 81.5
ls rods/b16 pistons
ge lsvtec kit
aeb studs
arp bolts
machine work done by DG motorsports
STock b16 head
I wasnt there when he started the motor but, it started out with a high idle at 4k rpm he said. Then after that it wont start, he said there wasnt any knocking. Now when he tries to start the motor again it wont start, but you can hear the motor bogging ...I was wondering what could be wrong. I dont know much, but ill go check it out tommmorrow.
Old Oct 8, 2008 | 07:53 PM
solturbob16sol's Avatar
* B A N N E D *
Default Re: ls/vtec problem (jim9)
timing
Old Oct 8, 2008 | 08:23 PM
UncleD's Avatar
Default Re: ls/vtec problem (solturbob16sol)
What ecu are you using? Is he using a AFR? What do the plugs look like?
Old Oct 8, 2008 | 08:27 PM
jim9's Avatar
Default Re: ls/vtec problem (clean rice)
Ah, havent ask him that. Is there a certain sparkplug that is required? I was thinking it is the timing now since when he tries to start he said it boggs...
Old Oct 8, 2008 | 08:32 PM
UncleD's Avatar
Sounds to me like the plugs are fowled and it's having a hard time firing. Just go to Schucks or something and get some plugs for an ITR(NGK).
Old Oct 9, 2008 | 12:18 AM
grub's Avatar
i just buld a lsvtec. ls bottom end and pr4 pistons on stock rods the crank was turnd and acl bearings.b16 head and a grand total of 450$ in all i use a pr4 ecu that i chiped and coveted it to a p28 and tuned.it only put down 153 to the wheels it turnd out just fine i put it in a del sol and ran 14.2 in the quarter. i have pland to put 450 injectors and retune with spray.but i ran in to some **** like that and it was the ecu i have to mess with the tune
Old Oct 9, 2008 | 07:07 PM
v-techsilo's Avatar
it will be running strong will be up
there with tha gsr =D
bebe101
Nov 21, 2008 05:32 PM
JDMbitches
16
Aug 15, 2006 09:25 PM
BOOSTEDgreeneg
10
Feb 28, 2006 04:36 PM
KornyCivic
Nov 15, 2005 12:41 PM
ajzeg
Mar 5, 2005 09:21 PM
