Bearings behind axle seals - grease them?
Old Oct 8, 2008 | 07:46 PM
Jonathan_ED3's Avatar
Default Bearings behind axle seals - grease them?
This is something I've never thought about, and hence my question.
I'm replacing my axle seals. There's a large bearing behind each one - it LOOKS like there used to be grease packed in there. Is this accurate? Or does it just LOOK like grease on my old busted down L3?
I'm wondering if I should try to repack them, or what? Or do they get lubricated by the MTF?
TIA!
Old Oct 8, 2008 | 09:32 PM
onepoint6i's Avatar
Default Re: Bearings behind axle seals - grease them? (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">
TIA! </TD></TR></TABLE>
YES
Old Oct 8, 2008 | 11:17 PM
91civiccross's Avatar
Default Re: Bearings behind axle seals - grease them? (onepoint6i)
The only thing you grease in that area is the inside of the seals (where the axel touches the seal). If you got the seals from Honda they are already greased for you.
TNSteel
Sep 3, 2013 09:35 PM
97grnrs
Oct 3, 2006 02:52 PM
SiMateoAko
11
Apr 16, 2006 05:35 PM
litterbox
Feb 12, 2005 05:19 PM
