OBD1 GSR Getting no spark after wire tuck <-----------
Old Oct 8, 2008 | 07:27 PM
vietnamezerice's Avatar
Default OBD1 GSR Getting no spark after wire tuck <-----------
Alright guys, I try to help everyone here and now it's my turn to ask for help. I have a 95 Integra with a GSR motor.. did a wire tuck, I have never driven this car so as far as I'm concerned the wiring in the body should be ok... I used my distributor on a friend's car and it runs fine.. but I get no spark out when it's in my car... I have power going to it (black/yellow stripe) what else can I check for?
Old Oct 8, 2008 | 08:06 PM
ruffrhyder's Avatar
Default Re: OBD1 GSR Getting no spark after wire tuck <----------- (vietnamezerice)
What wires did you tuck?
Old Oct 8, 2008 | 08:32 PM
Default Re: OBD1 GSR Getting no spark after wire tuck <----------- (ruffrhyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">What wires did you tuck?</TD></TR></TABLE>
well.. i removed all my ac/heat components and routed the engine harness through the hole for the heater core...
Old Oct 9, 2008 | 12:33 PM
help?
Old Oct 9, 2008 | 02:12 PM
g0tgot's Avatar
ond1 or 2 distributor / motor combonation?
Old Oct 9, 2008 | 06:52 PM
Default Re: (g0tgot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot &raquo;</TD></TR><TR><TD CLASS="quote">ond1 or 2 distributor / motor combonation?</TD></TR></TABLE>
everything is OBD1
Old Oct 9, 2008 | 07:00 PM
__oversea's Avatar
double check all the connectors and make sure wires are not cut or un-hooked during plug in?
Old Oct 9, 2008 | 07:20 PM
Default Re: OBD1 GSR Getting no spark after wire tuck <----------- (__oversea)
which connectors are important for spark? I have power going to the distributor... which wire is the signal wire?
Old Oct 10, 2008 | 05:47 AM
i want to get my baby started!
Old Oct 10, 2008 | 06:26 AM
AWD Terror's Avatar
This might help:
http://www.team-integra.net/se...=1112
Old Oct 10, 2008 | 03:18 PM
Default Re: OBD1 GSR Getting no spark after wire tuck <----------- (AWD Terror)
i put my distributor on my friend's car and it cranked right up... so i know nothing's wrong with my distributor
Old Oct 10, 2008 | 07:26 PM
i relocated my battery to the trunk and I have a tranny ground and a ground from the radiator support to the head would I need more ground?
Old Oct 10, 2008 | 10:26 PM
ironcheftony's Avatar
make sure you have the harness plugs plug'd into the right plugs, cuz like 2 of them are they same
Old Oct 10, 2008 | 10:41 PM
Default Re: (ironcheftony)
i marked and labeled each plug but I'll double check tomorrow
Old Oct 11, 2008 | 06:26 AM
Default Re: (vietnamezerice)
up, for more help
Old Oct 11, 2008 | 08:24 AM
check your fuses
Old Oct 11, 2008 | 07:01 PM
which fuses am I checking for?
Old Oct 14, 2008 | 07:51 AM
Old Oct 14, 2008 | 09:22 PM
comon guys! help a brother out!
Old Oct 15, 2008 | 12:24 PM
Old Oct 15, 2008 | 09:23 PM
am I the only one here?
Old Oct 15, 2008 | 09:29 PM
scion_eternity's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">which fuses am I checking for?</TD></TR></TABLE>
any fuse thats burned, check the fuses and relays under the hood
Old Oct 15, 2008 | 09:30 PM
Default Re: (scion_eternity)
that fuse box now resides behind the firewall I'll check it out though... on second thought i don't think there's any fuses or relays that would affect spark?
Old Oct 15, 2008 | 09:35 PM
typer_eternity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">that fuse box now resides behind the firewall I'll check it out though... on second thought i don't think there's any fuses or relays that would affect spark?</TD></TR></TABLE>
yeah that box and i think there is a fuse related to your ecu so you might wanna check that out.
Old Oct 15, 2008 | 09:37 PM
Default Re: (typer_eternity)
well my fuel pump primes... if the ecu fuse wasn't good the car wouldn't prime at all right?
