h22 swap accord help?? ecu problem??
i swapped an h22a in my 95 accord about 2 months ago. everything was running fine. expect that it was running like an sohc would. when i got the swap done it was still using the f22 ecu. they said it will be fine for now till we find an h22 ecu for it. then i was doing some work with replacing the electric portion of the ignition switch. after i was done with that. my car started running like shiet after couple of mins. its running really lean and back firing and hesitating. im thinking its running like this because of the fuel pressure and the maps. im thinking its something with the f22 ecu. im trying to find a p13 or chipped p28 right now. but any advice would be good. anything else that would be helpful.
also when i get the h22 ecu would it just plug right up or would i have to do some work with it??
thanks.
thanks.
it should plug right in if you did the wiring correctly. I would just go for the P13 b/c I have a P28 chiped and the vtec is not as noticable as in the P13.
