Just put on Eibach Pro Kit on gsr and ABS light is on.
Old Jul 28, 2002 | 06:56 AM
apexiintegra's Avatar
Default Just put on Eibach Pro Kit on gsr and ABS light is on.
Hey can somone tell me what I should do because I just installed a pro kit in my gsr and the ABS light is on.
Old Jul 28, 2002 | 10:22 AM
Integra_Nguyen's Avatar
Default Re: Just put on Eibach Pro Kit on gsr and ABS light is on. (apexiintegra)
Sorry, I'm not much help but I want to install pro kits and I'd like to see a picture of your car. Um, maybe you should check the brake fluid too.
Old Jul 28, 2002 | 10:37 AM
non-VTEC's Avatar
you must have pulled or pinched one of the ABS wires while installing your new springs............double check all the ABS wires and sensors for damage........
Old Jul 28, 2002 | 03:48 PM
Tweakmeister's Avatar
yeah check the wires.
if you don't have a Helms manual (shop manual) then it would be a good investment. http://www.helminc.com
the abs wires are pretty easy to locate.
Old Jul 29, 2002 | 06:22 AM
batboyvaj's Avatar
Default Re: Just put on Eibach Pro Kit on gsr and ABS light is on. (Tweakmeister)
i was having the same prob. i accendently tugged on the wire on the drivers side. but i ran a code and it told me high pressure leak?
irideslammed5021
Feb 25, 2010 06:05 AM
94integrasc
Jun 27, 2006 07:12 PM
RNPoo7
Nov 21, 2005 02:08 PM
94~GSR
Sep 30, 2005 10:33 PM
vtran8
Jul 14, 2003 01:02 AM
