s2k pcx ecu pinout needed
What all exactly are you looking for? If you are pretty much looking for an OBD2b pinout diagram here ya go
I haven't necessarily directly compared all the pins to an S2000 ECU (I would definitely suggest this), but I had to splice wires to the C connector and everything on the wiring diagram for my voltage clamp matched the pins on the harness. It was only 4 wires though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker »</TD></TR><TR><TD CLASS="quote">If you are pretty much looking for an OBD2b pinout diagram here ya go
He is correct, a good amt of the wires on the OBD2B pinout are the same. This is up to 05...
Here is one that I know is correct... It may not cover everything you need though.
http://www.innovatemotorsports...0.php
This is useful if you are installing an alarm.
http://www.the12volt.com/insta...68824
This one has a few more wires mentioned... This should be all you need I would think.
http://www.plxdevices.com/ECUD...4.pdf
jerr
Oct 26, 2008 11:32 AM
