Trying to make 200whp!!!
hey guy's,
ok so i have a 02 hatch with some minor upgrades:
F5 Fujita Cold Air
Progress Rear Sway
Skunk2 Rear LCA'S
GC coils
Koni Yellows
Lots's of little thing's
Mostly suspension, but my goal is to reach 200whp as cheap and as easily as i can. I want to go all motor, and i was thinking of swapping to a Type-S head. My ? is, are any sensors or brackets different from the A3 head, will it bolt right up? Im 17 so money is tight and i will be doing all the work myself. And how much power could i get from this. Thanks
F5 Fujita Cold Air
Progress Rear Sway
Skunk2 Rear LCA'S
GC coils
Koni Yellows
yeah sorry cheap and N/A are not two words that go together. If you had the Z1 engine originally 200whp+ is easy with standard bolt ons. The k20a2 is close, but falls a little short.
I would go K-pro, RH, Exhaust and call it a day until you save up enough money for something serious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-’S’paz »</TD></TR><TR><TD CLASS="quote">yeah sorry cheap and N/A are not two words that go together. If you had the Z1 engine originally 200whp+ is easy with standard bolt ons. The k20a2 is close, but falls a little short.
I would go K-pro, RH, Exhaust and call it a day until you save up enough money for something serious. </TD></TR></TABLE>the z1 engine has 200 hp at the crank, with the mods you listed you would be a lil above 200 hp depending on how you get it tuned.
Modified by nahonda04 at 6:39 PM 10/8/2008
Don't bother doing the A2 head swap.
Cheaper and less headache and less down time to just buy an A2 longblock.
Then do I/RH/E and K-pro, 200whp no problem.
broketuner-Sol_Si
Suspension & Brakes
Apr 15, 2007 11:45 PM
hott-nix
Mar 13, 2005 04:38 PM
JG Luder
24
Oct 18, 2001 01:42 PM
