what psi should my fuel pressure reg. be set to?
Old Oct 8, 2008 | 06:29 AM
toda_ef9's Avatar
Default what psi should my fuel pressure reg. be set to?
i have a 90 si with an obd2 b20. what should i have my fuel pressure regulator set at?
Old Oct 8, 2008 | 02:32 PM
sgallagher's Avatar
Default Re: what psi should my fuel pressure reg. be set to? (toda_ef9)
Why do you have a fuel pressure regulator if you don't know how to use it.
What mods do you have? What ECU are you running, do you have an A/F gauge connected to a wide band O2?
Old Oct 8, 2008 | 02:40 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toda_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 si with an obd2 b20. what should i have my fuel pressure regulator set at?</TD></TR></TABLE>
Unless you have changed cams or internals....Use the stock.
Old Oct 8, 2008 | 06:13 PM
dacrxguy's Avatar
a cheap way of getting around buying a fuel pressure regulator to put more fuel in is just pulling the vacuum line off the regulator but then u will always be running rich which is not good for a b20 stock presure i would have to look it up how much psi are u running now
Old Oct 8, 2008 | 07:40 PM
ttm_sales's Avatar
Around 45psi
vpower101
Oct 30, 2010 03:44 PM
vpower101
Oct 29, 2010 06:57 PM
vpower101
22
Oct 29, 2010 01:26 PM
NuclearB18B
Sep 19, 2003 06:20 AM
RaVAGE00
Jun 9, 2002 07:58 PM
