WTB : B series parts!
Ok heres a list of what i need. Will pay shipping on anything i need so dont be shy!
B16 or ITR hydro tranny with or w/o lsd is fine
Gsr or ITR oil pump
OBD2 VTEC Dizzy or OBD1 VTEC Dizzy WITH a jumper to obd2 harness
B18c rear main seal plate
B18c timing gear and associated hardware ( spacer washer ect.)
B18c crank pulley
B18c black vacuum box ( on rear of block )
B18c thermostat housing
B18c coolant pipe
B18c timing belt tensioner
B18c waterpump
B18c lower timing cover + hardware
B16 or ITR intake manifold with sensors included (dont need TB)
TB mounted MAP sensor
TPS sensor
B series VTEC solenoid
B series Coolant temp sensor and fan switch/sensor
94-01 integra LS throttle cable
94-01 integra shift linkage
96-98 civic EX 5 speed engine harness
94-01 integra any model AC bracket and front tranny bracket
99-00 Civic Si motor mounts ( or aftermarket b series into ek mounts )
99-00 Civic Si driver side post bracket for mount
OBD1 or OBD2 GSR or ITR injectors
BNIB Hondata IM gasket for B16/ITR
BNIB ARP B18c headstud set
OBD1 P72 or Hondata S300
OBD2A to OBD1 ECU jumper harness
PHEW...thats all i can think of now!
PM is key for contacting me! cash in hand for good deals!!!!
Gsr or ITR oil pump
B18c crank pulley
B18c coolant pipe
B18c waterpump
TPS sensor
99teggsr
Apr 25, 2005 08:35 PM
95DXPhiladeph
Jun 1, 2004 06:31 PM
