86 Honda accord not starting.....
Old Oct 8, 2008 | 01:35 AM
jwicecold's Avatar
Default 86 Honda accord not starting.....
Every time my homie goes to start his accord it doesnt turn over. All you hear is click click click. Im almost positive its the starter but antything else anyone is thinknin??? Im posting this for his reassurance. Thanks
Old Oct 8, 2008 | 03:46 AM
GhostAccord's Avatar
Default Re: 86 Honda accord not starting..... (jwicecold)
Low/dead battery. Test the battery for proper voltage.
Do the interior lights dim when you turn the ignition and try to engage the starter?
Old Oct 8, 2008 | 03:50 AM
jwicecold's Avatar
Its also an A/T.. And the dome light goes on when the key ignition is turned.. The battery has a charge and holds it.
Old Oct 8, 2008 | 04:07 AM
Default Re: (jwicecold)
Have you tried doing a strait shot from the battery (+) to the starter (+) to test it?
Give the starter (+) a little tap with an insulated wire from the battery to see if the starter engages.
Old Oct 8, 2008 | 08:42 AM
Matt G's Avatar
Charge your Battery, clean corrosion off of the cables, check your ground off of your battery as well. If all that is good I would check your starter solenoid. I found it on a wiring diagram on alldatadiy http://traffic.alldatadiy.com/...61766
Old Oct 8, 2008 | 10:14 AM
Default Re: 86 Honda accord not starting..... (Matt G)
Nice plug....Spam......Spam
Why pay for a monthly subscription for a tech website when you can
1. Download the Honda shop manuals online
2. Get TSB info for free online, and
3. Get free info from this and many other tech-sites.
Old Oct 8, 2008 | 05:38 PM
jwicecold's Avatar
Ya the starter was **** so was the alternator... thanks brotha for the help.
ms.ladyjones13
Sep 24, 2016 09:17 AM
J1MMY420
May 16, 2014 08:46 PM
jdmacuraITR
Apr 27, 2014 11:07 PM
kornerk12
Oct 25, 2008 11:27 AM
See Are X
Mar 6, 2003 10:08 PM
