LOOK WHATS WRONG HERE
im puting a d16y8 in my 91 crx hf.. i have a d15 bracket and a ef mount and this is what im geting.
please help me here
Modified by CRX Toad at 8:31 AM 10/8/2008
Modified by EJ8CIVIC at 6:27 PM 10/8/2008
please help me here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">im puting a d16y8 in my 91 crx hf.. i have a d15 bracket and a ef mount and this is what im geting.
please help me here</TD></TR></TABLE>
I did a similar thing in my Hf and I had to swap out the metal engine mount bracket that bolts to the engine itself to get it to line up with the motor mount. Take a look at your old mounts to see if you can't do the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nutnwrench »</TD></TR><TR><TD CLASS="quote">I did a similar thing in my Hf and I had to swap out the metal engine mount bracket that bolts to the engine itself to get it to line up with the motor mount. Take a look at your old mounts to see if you can't do the same.</TD></TR></TABLE>
this is the problem you must use the 88-91 bracket that bolts to the bolck under the timing cover.
91civicross the mount on the other side isnt even on yet...
and yes the bracket is from a ef d15 and i got the 90-91 si mount from autozone..
and if i unbolt the mount and line up the hole the motr mount will set crooked.....
grrrr >8-] pissn me off...
yes the mount is from autozone and the bracket bolted to the block is from a ef crx d15 ( from wat the person i bought said)
Got my HF swap with a 97 cx motor(not by choice) and they just weld my **** in...looks just like that only welded....I didn't care long as it was sturdy enough and my CRX was running again...until I'm ready for a swap of my choosing
though the Si tranny I picked up along with it I'm linking it for now
quick little POS
quick little POS
Excelerate
May 16, 2006 07:13 AM
slow91crx
Mar 29, 2006 04:33 PM
vitrox
Jun 11, 2004 05:31 PM
