What's the stock timing on a '92 VX supposed to be?
Old Jul 28, 2002 | 12:21 AM
ESCALVANTE's Avatar
Default What's the stock timing on a '92 VX supposed to be?
When I went to do a smog check a while ago, the mechanic decreased the timing on my 103,xxx mile '92 VX because he said that it would not pass if he didn't. So, I let him retard it it (and it pass) but he never set it back to normal.
Before the timing decrease, my car was idling at a little under 1,000 RPM (maybe 950 RPM) and now it idles pretty roughly and at around 200-300 RPM.
BTW, I did try to get the guy to re-set the timing back to normal but it turns out that guy quite that very same day so nobody could help me. Anyway, a friend of mine said he would do it for free but he needed to know what the stock timing is to properly do it.
So, I would really appreciate it if someone would let me know what the stock timing settings are for a stock '92 VX engine (D15Z6 I believe??) are.
Thanks in advance.
Old Jul 29, 2002 | 12:32 AM
ESCALVANTE's Avatar
Default Re: What's the stock timing on a '92 VX supposed to be? (ESCALVANTE)
ttt
Old Jul 29, 2002 | 02:51 AM
Mista Bone's Avatar
D Tranny Guru
16 BTDC, the center mark on the crank pulley when using a tming light
Old Jul 30, 2002 | 12:37 PM
ESCALVANTE's Avatar
Default Re: What's the stock timing on a '92 VX supposed to be? (Mista Bone)
Thanks Mista Bone!
Anyone got any suggestions on advancing the timing on a stock '92 VX in an attempt to make it more responsive?
18 BTDC sound good?
Thanks in advance.
Old Jul 30, 2002 | 12:39 PM
splitime's Avatar
d15z1, i have same car d15z6 is the si/ex i believe
Old Jul 30, 2002 | 12:43 PM
ESCALVANTE's Avatar
Default Re: What's the stock timing on a '92 VX supposed to be? (splitime)
Thanks for the correction splitime.
Any suggestions for increasing timing on the d15z1?
When timing is increased, what should I expect?
Lumpy idle?
Fast (read: high RPM) idle?
The engine to be more responsive?
Old Jul 30, 2002 | 03:56 PM
Mista Bone's Avatar
D Tranny Guru
yeah, don't mess with it. with the VX being a lean burn setup, not gonna help much if any.
jlk16188
28
May 4, 2026 07:57 PM
laloquera916
Oct 19, 2010 07:26 PM
a vtec life!!!
Sep 12, 2009 11:17 AM
92egSnatch
Apr 14, 2008 12:24 PM
Yellow Dragon
Sep 10, 2002 08:18 PM
