Manual transmission drain
Old Oct 7, 2008 | 08:35 AM
discoinferno65's Avatar
Default Manual transmission drain
So i recently got a 1992 Honda Accord LX and was giving it a full tune up when i got to the transmission. should i change the filter? i drained it and thought i was going to have a problem since its a square wrench that i'd need but the end of my socket wrench worked fine. However if i would have looked a little higher at the fill plug i would have noticed that whoever last had it stripped it. are my only options to take off the passenger tire and some suspension parts then tap and drill it out or does anyone have any other ideas that might work better?
Old Oct 7, 2008 | 08:40 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Manual transmission drain (discoinferno65)
no filter to change on the transmission.
what exactly is stripped? the threads of the fill plug, the head of the fill plug or the threads where the fill plug goes in the transmission housing?
I wouldn't be drilling and tapping the transmission housing without someway of knowing I can get all the metal bits out of the trans first.
Old Oct 7, 2008 | 06:17 PM
Default Re: Manual transmission drain (TouringAccord)
the head of the fill plug is stripped. I can get a decent grip on it but it seems to be on there tight and i can feel my 17mm wrench slipping off the bolt
Old Oct 7, 2008 | 06:19 PM
TheMuffinMan's Avatar
He knows where you live!
I've always taken off my passenger tire to access those bolts. Definitely should give you a better angle.
Old Oct 7, 2008 | 06:29 PM
H-T Order of Merit
if it's the head of the bolt then you don't need to drill anything.
get a bolt/nut extractor of the correct size from sears, I've used them a couple of times on rounded nuts/bolts and they have worked good.
they look like this...
http://www.sears.com/shc/s/p_1...6000P
and like TheMuffinMan said, remove the wheel to get make sure you get at the bolt at a good angle.
Old Oct 7, 2008 | 08:42 PM
your able to get to the drain plug with a socket wrench by removing the passenger tire? also do you know if you can still put in a quart of Lucas brand transmission fluid in with the 10-w30 oil that is recommended for the transmission?
Old Oct 8, 2008 | 05:46 AM
Heat's Avatar
Just buy Honda OEM manual transmission fluid, only about $5 or $6 a quart.
I don't know the capacity of the '92 but most likely around 3 quarts.
Old Oct 8, 2009 | 05:01 PM
gtaboy24's Avatar
New User
I have the same problem with filler plug...cant get the socket...can i add the fluid from the top some kinda way? if so how?
92 accord dx
Old Oct 8, 2009 | 05:16 PM
uberEFtuner's Avatar
I read that u can remove the vehicle speed sensor and fill it through that hole. Obviously you need to use the recommended amount of fluid.
mashguy4077
Jun 9, 2013 12:40 PM
MI4$DC5
Mar 11, 2006 07:56 PM
maivietla
Mar 22, 2005 07:02 PM
Matgallis
Nov 10, 2003 01:19 PM
