NEED HELP PLEASE! Rough drive and Code 43...
Old Oct 7, 2008 | 04:51 AM
jonwrong's Avatar
Default NEED HELP PLEASE! Rough drive and Code 43...
This problem is occurring with my 1992 Accord EX. My CEL has been coming on and going off for a few months now. Following this issue, the car started to hesitate or jolt under 2-3k rpms. The problem never occurred above 3500 rpm or WOT. In fact, WOT always corrected it. I have run sea foam through a tank of gas. I have replaced the fuel filter. I have replaced the O2 sensor and the air filter. The problem is getting worse, and it throws a code 43 every time I drive the car, almost immediately. The fuel filter fittings are tight; the compression in the motor is near perfect. Spark plugs have been replaced and look fine. Does anyone else have any suggestions; I am about to have to break down and take it in... I hate doing this b/c I never trust mechanics. THANKS for all your help in ADVANCE!
Old Oct 7, 2008 | 05:01 PM
Launchpad's Avatar
Default Re: NEED HELP PLEASE! Rough drive and Code 43... (jonwrong)
Sounds like maybe your egr system needs to be cleaned out do a search on how to clean it
Old Oct 8, 2008 | 05:21 PM
jonwrong's Avatar
bump
Old Oct 8, 2008 | 07:04 PM
ricebike's Avatar
43= Fuel Supply System
was this code before you change the fuel filter or after you did it???
if it was the latter, maybe you got a bad filter <shrugs> or maybe the seafoam cleaned out alot of crap & has clogged the fuel sock w/in the tank/sump
jonwrong
Oct 27, 2021 12:33 PM
crxpwr1
Sep 9, 2008 03:27 AM
mozzandherb
Dec 15, 2006 08:31 AM
simplegreenmachine
Jan 28, 2006 05:52 PM
93CharcoalHatch
Oct 20, 2005 03:15 AM
