'91 Accord damaged door lock
Old Oct 6, 2008 | 09:50 PM
Agent00J's Avatar
Default '91 Accord damaged door lock
A friend of mine has a '91 Accord that was broken into some odd months back. The passenger front door lock and handle were damaged. Passenger door can't be unlocked by key or anything. Also, the lock goes up for like a half second (when using the central locking to unlock) and slams back down.
Money is kind of tight right now so some friends and I want to try to fix the door for her. Problem is, with the door locked like it is I can't seem to remove the door panel without damaging it. Any suggestions?
pics...
Old Oct 7, 2008 | 05:08 AM
gqstatus05's Avatar
Default Re: '91 Accord damaged door lock (Agent00J)
So the door cannot open? Is that what you are saying?
Did a google search for "removing door panel 91 accord" you real quick, page 2 of the results.
I got "You’ll like that because to get the door panel off you have to remove the driver’s seat. With the seat out of the way you won’t have to be a contortionist to remove the door panel. But, you may want to call your chiropractor in advance for an appointment."
Oh yeah try to clean up that little rust so it doesn't get worse. Sucks when people try to break in.
Old Oct 7, 2008 | 09:20 AM
Agent00J's Avatar
Default Re: '91 Accord damaged door lock (gqstatus05)
Yeah, the front passenger door won't open at all.
Thanks for the help. I found some info on google. One link suggested drilling out the latch.
I'll post what I found here incase someone else needs the info...
1991 Honda Accord LX door lock jammed
1991 honda accord driver door won't open
Honda Accord Door Panel removal
And this was a little weird, but...
How to drill open a honda door
Modified by Agent00J at 10:26 AM 10/7/2008
Old Oct 7, 2008 | 08:11 PM
gqstatus05's Avatar
Yeah I would avoid drilling unless you know the right spot to drill. Try to take off seat and work that way. It shouldnt' be hard fix.
efiftythree
Jun 6, 2020 01:14 PM
CXHatchback
Mar 7, 2020 09:21 PM
Shadowsstrife
Apr 21, 2017 06:51 PM
bobkatzzz
Oct 21, 2005 05:28 PM
