Problems w/ JDM B18B into a '91 DX. Top Motor Mount won't fit the motor mnt bracket.
I'm trying to put a B18b in my EF, but the top motor mount bracket won't fit my "Innovative Mounts" top motor mount that came with the B-Series swap kit. Has anyone had this problem? The one that doesn't fit is the T-mount in the back and the top motor mount on the driver's side near the timing belt cover.
you can't use the bracket that is bolted to the b18b under the timing cover, you need to get one from a 1990-1993 integra. you may also need the rear T bracket from a 90-93 integra. i have the rear T bracket if you wanna buy it.
crx18c1
Jun 24, 2007 06:51 PM
