Help me street tune my b18c!!
Old Oct 6, 2008 | 05:06 PM
I CRX I's Avatar
Default Help me street tune my b18c!!
im running a jdm p72 chipped on crome with the ostrich emulator and i took a crack at tunning my idle the other day (first time)and got no where! i also have an innovate LM1 im using and it tells me @ idle im arounf 17 afr after the car was warmed up, so i opened crome, removed checsum routine, and enabled realtime programming and started increasing fuel in columns 1&2 (500-750 rpms) but wasnt really getting much change. at least nothing really noticeable and i didnt want to go crazy adding uber fuel....what am i dooing wrong? BTW im running a stock usdm p72 base but my motor is a jdm gsr with i/h/2.5'' ex. if anybody can give me a step by step on getting started with crome (free version) i would greatly appreciate it. also, timing was untouched.
Old Oct 6, 2008 | 07:21 PM
Tomdata's Avatar
Default Re: Help me street tune my b18c!! (I CRX I)
Ok buddy here it is in five steps. I bet you forgot step number 2.
Step zero. have the ostrich hooked up to the ecu and the laptop. Also have the key in the OFF <U></U> position. Do not attempt to turn the key on or start the car until after step five and you should be fine.
Step one. After you open your base rom you need to disable the checksum routine
Step two. You need to add the quickdatalogger + RTP (real time programming) plugin
Step three. Click on the realtime programming "chip" picture.
Step four. Click "putt" to send the new rom to the ostrich.
Step five. Click the "realtime update" button.
After completing these five steps you should be able to start the car and tune your car in real time using an ostrich and any version of crome.
Ok... here is a little secret. You can tell the realtime emulation is working because every time you make a change to the rom a counter in the lower right hand part of the screen counts down the bites being transfered. Now this happens really fast and tends to just look like a little black flash but it is there. If you highlight the entire low cam fuel rom and then hold down control and tap the up arrow one time it will be a big enough change to actually see the counter. I do this everytime I tune a car to check and make sure the realtime emulation is working properly.
Let us know if this works out for you.
Old Oct 7, 2008 | 09:33 AM
b20beast83's Avatar
Default Re: Help me street tune my b18c!! (Tomdata)
thanks for the tip.
to add to this,
colums 1-5 are what? part throttle?
and 9-10 are wot right
so 6-8 are what colums?
Old Oct 7, 2008 | 08:19 PM
I CRX I's Avatar
awesome!!! i'll update you ASAP. now for one more question, where do you think my target afr should be at WOT? and shuld i try to adjust timing also or leave that for a dyno?
Old Oct 9, 2008 | 07:41 AM
I CRX I's Avatar
antbody?
Old Oct 9, 2008 | 10:29 AM
b20beast83's Avatar
whats the setup
Old Oct 9, 2008 | 01:59 PM
I CRX I's Avatar
worked like a charm!!! the stock crome basemap was leaning my motor out like a muthasucka.....17.XXX @ idle! as stated above, im running a stock jdm b18c gsr with I/4-1 header/2.5'' ex.
Old Oct 9, 2008 | 05:14 PM
Tomdata's Avatar
Default Re: (I CRX I)
shoot for low 13's afr at wot. tune the rest of the map to about 14.0-15.0 when its warmed up and you should be pretty well off.
BTW.
you can put me in your vouches on your sig if you feel I deserve it
Old Oct 9, 2008 | 05:34 PM
I CRX I's Avatar
Default Re: (Tomdata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata &raquo;</TD></TR><TR><TD CLASS="quote">shoot for low 13's afr at wot. tune the rest of the map to about 14.0-15.0 when its warmed up and you should be pretty well off.
BTW.
you can put me in your vouches on your sig if you feel I deserve it </TD></TR></TABLE>DONE! any idea on timing?
Old Oct 10, 2008 | 07:04 PM
I CRX I's Avatar
also, what am i able to see when datalogging? i have an extreme hulog and was wondering if anybdy has tried using logworks from innovates site to log with a hulog? is there anyway of logging or viewing where my timing is currently at? sorry for the noob questions, just trying to cover the basics
Old Oct 11, 2008 | 09:35 PM
Tomdata's Avatar
If you use the HuLog and any major OBD1 tuning softwareyou will be able to see anything and everything you need to tune your car. IAT, ECT, TIMING, AFR, TPS, MAP,RPM, Battery voltage, etc.
Old Oct 12, 2008 | 10:00 PM
Xavien1s's Avatar
nice tips
Old Oct 16, 2008 | 04:49 PM
blakkvtec's Avatar
Default Re: (Xavien1s)
Crossing this tread more than helped me. Thank to the OG that had the problem and the Problem Solver!
hon2984
Jun 10, 2009 01:20 PM
CRX VT-DOO
Engine Management and Tuning
Jun 17, 2008 07:53 AM
rbanke
Sep 12, 2006 12:13 AM
sleepyEK
Sep 6, 2005 01:14 PM
