noob swap question
I've been reading alot of posts, frequently asked questions, and I've done alot of searching on here and I didn't find everything I was looking for (found answers to most of them though) I am new to hondas and this site has helped a ton, but anyways here are my questions I'm still not sure on...
I've got a 91 crx hf, and a friend of mine has a d16z6 and a 91si and a 94si (i think) tranny I would like to know if the d16z6 will fit in the car with 91si mounts, or do I need different mounts? Also, will my hf shift linkage work? If not, what linkage would I need? Thanks.
I am going with rywire's obd0 to obd1 conversion harness and a p28 ecu. I also have si axles already too. Any other parts I need please fill me in. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldbomb79 »</TD></TR><TR><TD CLASS="quote">
the 91 si mounts will work, the hf linkage will work. u can't use the 94 transmission it is hydrolic. if you use si axles you will need either dx or si suspension knuckles.
94HybridEX
Sep 9, 2002 07:00 PM
