95 Civic coupe B18C gsr build - plans for boost!
Hey Honda-Tech!
Fist I would like to say welcome to my first build thread. Your comments, opinions, thoughts, bumps, and advice are welcome!
Been a member on this board for a while, so I decided to start a build thread of my own
I currently drive a 95 EJ1 but my stock motor started ticking on me 2 months ago. My dad said we'll fix it but after 2 years and 2 Eg's it was finally time for a swap! Coming home from work I redlined first....and at around 5000rpm it just blew. Craked the block! NICE.
My plans....
I found a jdm B18C gsr motor w. tranny, p28 chipped ecu, shafts, dizzy for $1000
I'm keeping the internals stock and running boost to make 290HP.
Pics
My first car, 93 Lx. Got it when I was 16 as a gift from a family friend.
When I was done with it....
My Ej1 when I bought it in 2007.
Now...
When I blew the D16z6.
Modified by suno at 5:32 PM 10/6/2008
My plans....
I'm keeping the internals stock and running boost to make 290HP. Pics
Now...
Update: October 18
Got some parts in yesterday
Does anyone have any experience with the Exedy clutches and how the Stage 2 will feel on the street? I didn't get a lightweight flywheel but I am machining it down to 12lbs.
I'm still waiting for the cam gears to come in and then it goes straight to the engine shop! Can't wait!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suno »</TD></TR><TR><TD CLASS="quote">Thanks!
I wish I could do this faster but money is an issue right now...going to ask my boss for a raise on Monday
Didn't get a raise...but I got another part time job. So now I got 2 jobs to get this mother[freak]er done!
Sent the engine to the machine shop on Monday.
Getting: -flywheel resurfaced to 13lbs
-installing 2mm head gasket
- inspecting the piston rings
- valve clean-up
- clutch install
- cam gears installed
</TD></TR></TABLE>Didn't get a raise...but I got another part time job. So now I got 2 jobs to get this mother[freak]er done!
- valve clean-up
- clutch install
If you still need a bracket i may be able to find one. Im in ottawa. That clutch is not bad, i did the same clutch on a eg hatch b18c years ago. You will have to learn how to not slip it so much.
Yeah right rust free lol! When I got the car the quarters were crap so I just did a simple bondo job. After the winter the rust started coming into the trunk.
Rust is just stage one weight reduction =D
And I tried looking at your Ej1 build thread but it says the page does not exist!
**** i pulled near 40lbs of sand and rust out of my EJ1.
Fixed the link.
https://honda-tech.com/forums/appearance-build-threads-122/eg-project-95-civic-si-rust-bucket-2398771/
Yeah the clutch is not to bad in street traffic i find its aggressive but its nice
Fixed the link.
Dec 5
Ran into a little bit of problems the other day.
As my friends and I were towing my car to the shop, (we attached a rope to my tow hook and his Sprinter) a cop pulled us over with only 5 minutes left to go. He said this is illegal and we can't continue lol.
Here is the cop closing down the street so we can push the car into a nearby parking lot.
Waiting in the freezing rain for an hour, @ 1am, empty parking lot, a flat bed finally arrived!
Once I had dirty hands so I drove with blue latex gloves, got pulled over by a cop
Had some time today so I took apart my old motor.
Cause of failure: oil starvation at the crank oil squirter on cylinder 1.
Hole in the oil pan from the crank!
