tranny fluid help?
Old Oct 6, 2008 | 01:51 PM
TheAverageBear's Avatar
Default tranny fluid help?
so i bought one of those magnetic transmission drain plugs from password jdm and i was a little to excited or something and rushed into installing it without thinking, and thought there was alot less tranny fluid then there was so a bunch of it is on the ground, i saved 2 litres of it, but my question is, will i be okay to drive with only 2 litres? like drive into the city and buy some more? that or will it be alright to mix 5w-30 oil with my tranny fluid, which is royal purple by the way?
Old Oct 6, 2008 | 05:43 PM
Default Re: tranny fluid help? (TheAverageBear)
bumpp
Old Oct 6, 2008 | 05:50 PM
sp00nek9's Avatar
i think you will be fine either way. synchromesh is where its at tho
Old Oct 6, 2008 | 05:58 PM
cycopath's Avatar
* B A N N E D *
You will deff tell a difference in how the transmission shifts. It will be very stiff and jerk. Why don't you just fill it up again?
Old Oct 6, 2008 | 07:06 PM
Default Re: tranny fluid help? (cycopath)
well yeah man thats waht i wanna do. but will i be fine driving to go get some? cause i don't have any here, i just dont wanna [freak] it up withthe low fluid?..... thats gm synchromesh right? i was thinking of trying it, maybe i'll just completely change it, even tho the royal purple is only like 2 months old
Old Oct 6, 2008 | 08:35 PM
does anyone know the exac amount of fluid a y21 transmission can hold?
Old Oct 6, 2008 | 08:42 PM
geebs's Avatar
its just over 2 quarts i believe..
you dont have any engine oil laying around? just throw some 5-30 or 10-30 in there, go to the store and get some synchromesh, and drain it all out..
4door4lyfe's Avatar
2.5 quarts
Old Oct 6, 2008 | 10:18 PM
Default Re: (4door4lyfe)
is synchromesh really that good? i\ve never used it
Old Oct 7, 2008 | 12:20 AM
b16_sol_707's Avatar
I only use Honda transmission fluid. every transmission that I've used other fluids has gone out.
Old Oct 7, 2008 | 03:57 AM
Default Re: (b16_sol_707)
what do you mean has gone out? like ran out empty?
Old Oct 7, 2008 | 04:06 AM
Default Re: (TheAverageBear)
no, like has broken or had problems.
Old Oct 14, 2008 | 08:24 PM
k so i got the synchromesh, put it in along with my password drain plug, but when i drove it after i had a check engine light? and my speedometer would not work. so i took out the speedo sensor and inspected it, and installed it again, this time when i drove it the check engine light was gone, and my speedometer will jump to 20, then back down, and randomly stay at 20 for a while, any ideas waht my problem is?
Old Oct 14, 2008 | 08:30 PM
fmrprojects's Avatar
probably not all the way in.
Old Oct 15, 2008 | 05:36 PM
Default Re: (fmrprojects)
thats what i thought man, but i took it out twice and made sure i put it in properly
Old Oct 16, 2008 | 05:42 PM
so today i just said [freak] it and went and bought some honda MTF and ditched the synchromesh, i put the MTF in and still no speedometer, it doesn't even jump to 20 anymore.. so is it the sensor? or could something be damaged in the transmission? from only running 2 litres in it for the 40 kilometers i drove?
Old Oct 16, 2008 | 06:32 PM
cycopath's Avatar
* B A N N E D *
The sensor might of got damaged in the process of changing your oil. It happens. Thats the most likely possibility, as all you did was change fluid, which won't effect nothing. So you might of hit your sensor unplugging your transmission and it might be damaged now.
Old Oct 16, 2008 | 06:51 PM
oh really? that'd be awesome, this has been bugging me, ill go by a new one tomoro, give it a try and let you know how it goes
97CWITR
Jul 18, 2011 08:05 AM
phateless
Jun 23, 2009 10:39 AM
mikeintegra93
Jan 9, 2009 04:12 PM
sickofitall1113
May 16, 2007 01:57 PM
dork
Jul 9, 2004 09:27 AM
