99 Accord auto trans makes noise in Park/Neutral but not when put into gear
Old Oct 6, 2008 | 11:44 AM
dako66's Avatar
Default 99 Accord auto trans makes noise in Park/Neutral but not when put into gear
Hey guys,looking for some clues here. My Accord makes a grinding..ish noise when in Park or neutral but as soon as I put it in any gear it goes away. Someone mentioned possible torque converter, but looking for any other ideas. Wondering if anyone else has experienced same problem?
Thanks in advance.
Dave
Old Oct 7, 2008 | 09:29 AM
justin3po's Avatar
Default Re: 99 Accord auto trans makes noise in Park/Neutral but not when put into gear (dako66)
it sounds like you may have a busted cv joint the grinding noise is the joint spinning and grinding up against the other part of the shaft or anything around it look down in ur car and check them out
Old Oct 8, 2008 | 10:16 AM
dako66's Avatar
Default Re: 99 Accord auto trans makes noise in Park/Neutral but not when put into gear (justin3po)
Don't think it is the CV joint. The car drives just fine.
It only makes the noise when it is in Park or Neutral. For example when I get in and start the car, the noise is there. As soon as I put the car in reverse or Drive the noise goes away.
Old Oct 9, 2008 | 11:48 AM
csmiths98AV6's Avatar
its gonna be your tranny. they have had nothing but problems, go onto v6performance.com and under the 6th gen accords there is a huge thread with all the ppl with failed trannies. including me and i have had a few im my car as well
HSXVR-4
Apr 28, 2009 11:55 AM
roydogg
Sep 15, 2004 10:18 AM
Elvis1977
Feb 12, 2004 08:58 AM
jbashir
Oct 15, 2003 11:00 AM
