CEL code from Accord FAQ Missing?
need to look up a code or r they all the same regardless of what car u drive.
when I pull the blue plug with 2 wires on it from the glove compartment and jump them using paper clip. the SRS light blinks instead of the CEL.
am I doing it right.
95 Accord EX Sedan
Modified by bopbop93030 at 1:08 PM 10/6/2008
95 Accord EX Sedan
The SRS code is a two part code. Main System and Sub System
Example 5 flashes and then 2 flashes would be 5-2
Meaning the main unit has an internal problem, but you don't want that code. LOL
No - the SRS & DTCodes (CEL Flashes) are two different sets of codes.
The SRS is the Supplemental Restraint System it deals with your air bags and seat belt diagnostics. The OBDTCs or On Board Diagnostic Trouble Codes (CEL) are engine/trans related codes.
They have two different sets of lists.
What flash code are you getting from SRS?
I did not read it, I just disconnected it after it flashes.
I will redo it this weekend and let you guys know.
is it possible that my airbags is not working?
Modified by bopbop93030 at 5:42 PM 10/7/2008
