gear shortened.. (now what??)
Old Jul 27, 2002 | 07:43 PM
ShowSpeed's Avatar
Default gear shortened.. (now what??)
i understand the concept that a longer ratio would be needed(better) to make sure your turbo spool up (full potential)..
i have shorter gear ratios (higher final drive)... wouldn't this upset the turbo set up? then again.. if a supercharger is always pulling... wouldnt the FD enhance it JRSC even better then say turbo?
comments welcomed.
Old Jul 27, 2002 | 08:07 PM
ninesecrx's Avatar
Default Re: gear shortened.. (ShowSpeed)
I dont really understand your question, but you can run a taller or shorter tire with the same effect as changing gear ratios...
Old Jul 27, 2002 | 08:13 PM
ShowSpeed's Avatar
Default Re: gear shortened.. (ninesecrx)
to simplify>>>
longer gear ratio = better for turbo (because turbo needs time to spool up)
now... if shorter gear ratio... is that better for SC? (SC does not need time to spool.. power is there instantly)
hope this clairfies.
to rephrase.. "if i run JRSC.. is it better to have shorter or longer gear ratios?"
Old Jul 27, 2002 | 08:19 PM
SiRkid's Avatar
hmmm....its not that simple....yes and no in a way.
grosen
Honda CR-V & Element
Nov 18, 2018 01:29 AM
Bense
Mar 18, 2009 03:22 PM
Bobby Budds
Mar 24, 2007 08:47 PM
DC2_9
Nov 9, 2003 06:49 AM
