Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
airbag light
Old Oct 6, 2008 | 07:50 AM
mrbobolonian's Avatar
Default airbag light
just wondering hoe to turn off the airbag light on my 05 accord... i took it to the dealer to see what was wrong and they couldnt find anything. i know its usually the seatbelt thing but they said it wasnt. how do i turn the light off?
Old Oct 7, 2008 | 10:02 PM
p10hlm's Avatar
Default Re: airbag light (mrbobolonian)
you took it to the dealer but they could not find anything wrong.
man try taking it somewhere else dont let them touch your car lol
Old Oct 8, 2008 | 08:29 AM
Matt G's Avatar
I cleared the code manually using the SCS Service Connector to the MES 2P Connector under the left side of the dash. It is the only way to manually reset the SRS indicator I have ever seen from Honda. Check out http://traffic.alldatadiy.com/...61766for all your troubleshooting on the SRS system.
Old Oct 9, 2008 | 06:50 PM
maxpower98's Avatar
so you are saying that you took your car into a dealership and they said they couldnt find anything wrong and jsut shipped the car with the srs light still on. i find that hard to believe because that is a major liability. alot of times with the srs light on the airbags are disabled. i would take the car back to the dealership and demand that they fix the light.
Old Oct 10, 2008 | 06:26 AM
Ross 2.0's Avatar
In a Junkyard near you.
If the SRS light is on and there is no code you either have a bad srs unit or a bad alternator.
Old May 13, 2009 | 06:51 PM
spongecop's Avatar
can you elaborate why the alternator would cause the srs light to stay on?????
I am fighting the same problem. I replaced the srs module but the light wont reset and when I try to pull a code it does not blink.
thnks
Old May 14, 2009 | 01:58 AM
killa rex's Avatar
Has the car been in an accident b4?
Old May 14, 2009 | 05:16 AM
spongecop's Avatar
I got this car from my sister and by looking at the front she had a couple small fender benders. However, I believe she said they were while the car was parked at a mall.
I suspect that the battery light would come on if the alternator was bad.
tscholtens
Acura TL, RL & ZDX
Oct 12, 2013 08:39 PM
jdmrida
Nov 21, 2008 08:58 AM
Caveman74
Oct 30, 2006 02:55 PM
slowcivic888
Dec 15, 2004 06:32 AM
StolenTeg
Nov 28, 2004 08:19 AM
