1997 ACCORD EX TRANNY REPLACED WITH AN LX
Old Oct 6, 2008 | 05:05 AM
ronnel97's Avatar
Default 1997 ACCORD EX TRANNY REPLACED WITH AN LX
I am putting my Accord EX back together. My trans started slipping and so I found a junkyard with an LX trans($700) installed and had it replaced. My problem is the trans won't do over 70 mph and my dash keeps showing the trans flashing. I had to take car to another shop and they say I have a bad solenoid which may not allow the trans to go to overdrive??? Can anyone help me I have had the car since new and other then this she been GOOD to me. Does anyone know a Great shop or Mechanic in the Chicago area?? THANK YOU
Old Oct 6, 2008 | 07:29 AM
gqstatus05's Avatar
Default Re: 1997 ACCORD EX TRANNY REPLACED WITH AN LX (ronnel97)
Any check engine lights? $700 for a transmission is kind of steep for a junkyard price. Maybe it varies by your region.
If you have a CEL on go to autozone and they can scan it for you for free to see what the problem is. Do the RPM's jump around crazy? How's idling RPM's?
Old Oct 6, 2008 | 09:39 AM
bseriescrxsi's Avatar
Default Re: 1997 ACCORD EX TRANNY REPLACED WITH AN LX (gqstatus05)
a blinking d4 light may indicate that the solenoid lcated on the front of the transmission has gone bad/may not be hooked up......it is an easy fix you can do yourself if thats the problem
Old Oct 7, 2008 | 01:50 PM
ronnel97's Avatar
Default Re: 1997 ACCORD EX TRANNY REPLACED WITH AN LX (bseriescrxsi)
$700 was installed and I did think it was a little high. I do have a blinking D4 light and would the solenoid stop the car from going to overdrive?? Should I replace both solenoids on the trans and where can I get them at a low $$.
Old Oct 7, 2008 | 10:17 PM
now i know this sounds silly but did you check to make sure they reinstalled and hooked up the overdrive cable?
JDM_Mugen_CD6
Oct 2, 2016 12:35 PM
Kunfusion209
Mar 31, 2010 04:19 AM
sauceman54
Jan 14, 2009 05:32 PM
AMSOILERMAN
Oct 16, 2006 07:22 AM
1993accordrty
Apr 12, 2004 10:41 PM
