94 civic w/ 2000 h22 few question about h22
Old Oct 5, 2008 | 10:01 PM
AMD's Avatar
AMD
Default 94 civic w/ 2000 h22 few question about h22
ok so i just bought my friends 94 hatchie yesterday since he joined the service. its got a H22a1 engine, not very much room...,and im thinking bout pulling it out and building it up. i need to make up my mind about it. NA or turbo???
i like the NA idea just cuz everyone around here is turboed.
question
1. can i run 11.5:1 comp on pump gas or a higher comp??
i did a lil homework and i saw that h22 euro r it has a 11:1 comp. and mine has 10:1 comp.
2. could i do a stroker kit 2.4 with the highest comp on pump gas??
3. whats the deal with h23?
4. is a h22 sleaved like a b series engine?
5. wiring harness? obd2? or 1?? i think the car is obd1 and i dont have vtec. how or wat can i do to make it work? if i need a jumper witch 1 do i need to buy. the vtec is not pluged up since i have no wires that go to it.
6. would it be bad if i used my PYR LS chiped ecu with the engine for temp use??
7. witch ecu do i need to buy since the my bubby bought a jun chiped ecu that the vtec doesnt work?
8. how can i tell if the h22 is a 2000 year model and the tranny too??
if any one can answer my question that would be great.
Old Oct 6, 2008 | 02:45 AM
YeuEmMaiMai's Avatar
Default Re: 94 civic w/ 2000 h22 few question about h22 (AMD)
lol did you even read the forum before you posted?
you will most likely have better luck in the civic forum
Old Oct 6, 2008 | 03:25 AM
GhostAccord's Avatar
Default Re: 94 civic w/ 2000 h22 few question about h22 (YeuEmMaiMai)
But at least his questions are H22 related...lol
1. Yes. 11.5:1 with a good tune will work on pump gas.
2. Yes and 11.5:1 with a good tune will work on pump gas.
3. It's a 2.3L DOHC non VTEC. that's the deal.
4. H22 has FRM sleeves.
5. 94 Civic is OBD1 and the 2000 H22 is OBD2. Get a VTEC ECU and wire up the VTEC
6. It would be bad if it's not tuned to run an H22, and I'm guessing that it's not.
7. A chipped ECU that is tuned for your setup.
8. You can tell by What engine code is stamped on the block and what label is on the transmission?
Old Oct 6, 2008 | 06:03 PM
AMD's Avatar
AMD
but i figured that since its a H22 some one would have some answer.?
Old Oct 6, 2008 | 06:05 PM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMD &raquo;</TD></TR><TR><TD CLASS="quote">but i figured that since its a H22 some one would have some answer.? </TD></TR></TABLE>
H22's aren't from USDM Accords
nemesis25
Oct 21, 2010 04:10 PM
heaththemanshehan
Nov 14, 2008 05:59 PM
AMD
Oct 12, 2008 04:54 PM
inTeGra_LivesOn
Jan 1, 2005 07:39 PM
