Weird clutch stiffness problems
Hey guys, I was hoping somone could help me out with a problem that I've just encountered. I just got my s2k 2 weeks ago and the only thing mechanically that needed fixed was the clutch master cylinder due to leaking. Today I replaced it, bled the lines, and even added some grease to the clutch slave cylinder while I was down there. When I took it apart I found no grease on the rod/clutch fork. The only problem was when I put it all back together and bled the line I noticed that it squeeked when pressing the clutch down when it didn't before. Also the pedal wasn't very stiff so I adjusted it all the way I could to stiffen it up. A couple hours later I went out to test drive it and the pedal somehow mysteriously stiffened up wayy too stiff and had now squeeks or noises at all. Now I'm stuck with a problem that when I press down on the clutch, at the very END of the clutch pedal's travel, it seams to get stuck and not want to come back on it's own easily for an instant. So I'm confused as to why now it feels stuck at the bottom for a brief second, it makes it very difficult to drive and to get a feel for the clutch. Thanks for any help and sorry this is so long, just wanted to be as clear as possible. :D
