PLEASE post The GOOD and Bad and The Ugly about Vafcs
i Need to know the ups and downs about Vafc! Some may know more than outhers . so ill try to puzzle the post info and figure it out for myself, THANKS
PLEASE POST!
PLEASE POST!
If you don't want to cut into your wiring harness, you will have to invest in a 200 dollar harness converter. But if you use a soldering gun to do your wires, that does the same job with the same reliability.
http://www.jdmspecperf.com
Cons, those hidden costs. It's useless to you without dyno time for tuning.
ok, you got me. It WOULD be cool to mount it in the sunvisor. I never thought of that.
It just frustrates me because it's too tall for a din, and if you mount it there anyway, you can't put anything in the cup holder. Too much moisture. It looks lame on top of the dash. Its not supposed to be in direct sunlight anyway. In the instrument cluster bezel... not for me. Same for the glove box.
Anyone have a picture of one mounted in their sunvisor?
I love mine, its simple to tune with (some would argue with me on this) and it is reliable, I mess with it on my Integra all the time, I just dont lean it out too much until I am on the dyno.
should be getting my in two weeks, i only here nothing but good things about it.
but it isn't worth it if you don't go to a dyno.
pros-there more tunning avail than the Fields' vtec controlller(currently owned)
i kept throwing check engine code of vtec engagement failure. i have 3 other friends who expericened the same.
Is that Ish true about Gsr ecu's supposedly knocks over rides your Vafc, and ***** up alot of ****?
for the good - go to http://www.apexi-usa.com
for the bad - Dosen't show speed like fields, and dosent beep at shift point like fields, but better in every other possible way but those.
for the ugly - mounting it in the sunvisor (tell the guys behind you you have a VAFC)
if you are looking for a place to mount it, try ditching the ashtray. I have mine there and it is a perfect fit, alowing you to keep you cig lighter also.
hmm did you all 4 do the installs together?
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
