messed up idle?
Old Oct 5, 2008 | 02:34 PM
hastingsr's Avatar
Default messed up idle?
I have a 95 gsr and when I start up my car it will sit a 3k and then when it startes to warm up it will bounce from 2k to 3k, guessing its my tps sensor? i will occasionaly throw a cel but there are no places in town that have a obdI tester. any opinions on what it could be or what to do?
Old Oct 5, 2008 | 03:26 PM
sh4mr0ck's Avatar
Default Re: messed up idle? (hastingsr)
You could have an air lock in your cooling system, or your primary O2 sensor could be bad...
Old Oct 5, 2008 | 04:01 PM
hastingsr's Avatar
is the primary 02 sensor the one in the cat? I just took that one out and made a new bung for it and maby i damaged it when i out it back in?
Old Oct 5, 2008 | 04:15 PM
sh4mr0ck's Avatar
Default Re: (hastingsr)
The primary is the one before the cat. There should be two O2 sensors, one before the cat determining if the air/fuel mixture is correct, and one after to determine if the cat is doing the correct job.
Old Oct 5, 2008 | 04:27 PM
hastingsr's Avatar
Only 02 sensor I see is at the end of my downpipe and front of my cat. were is the other?
Old Oct 5, 2008 | 04:33 PM
hastingsr's Avatar
but most of the time im not throwing a code only everyone once in awhile and it goes away so i wouldnbt think it would be a bad sensor because i would always be throwing a code, maby i could have a vacume leak?
Old Oct 5, 2008 | 05:15 PM
stock01gsr's Avatar
it sounds like it could be your IAC valve. i had a similar problem in my teg all i did was remove it and clean it with some carb cleaner.
Old Oct 8, 2008 | 07:43 PM
hastingsr's Avatar
anyone els have some ideas? seems to be burning gas too
Old Oct 8, 2008 | 07:53 PM
vietnamezerice's Avatar
your car is OBD1... it only has 1 O2 sensor which is before the cat... try cleaning your IACV first and then move to other areas
Old Oct 9, 2008 | 03:05 AM
hastingsr's Avatar
if my o2 sensor was bad would i b throwing a code all the time? becasue i thrwo a code sometimes n when i last looked at it it didnt look too healthy
Old Oct 11, 2008 | 02:16 PM
hastingsr's Avatar
well i know its not my iacv beause I cleaned the hell out of it and it didnt help... narrowing down the cause I guess
Old Oct 11, 2008 | 04:05 PM
mayoforlife2's Avatar
what all is done to your car? (engine mods) why don't you try reading the code your self manually with a paper clip , i think the connector is in the passenger kick panel ,someone help me out im not 100% sure where it is but you have to ground the connector out with the paper clip and read how many times the check engine light flashes, long flashes are the first digit and the fast flashes are the second digit of the code
Old Oct 11, 2008 | 05:51 PM
bunnyhatch93's Avatar
Default Re: (mayoforlife2)
https://honda-tech.com/zerothread?id=978933 Look in here it will tell u where to find and how to read ur CEL. also about ur idel problem, get a can of brake cleaner and spray around the gaskets on the intake manifold. just do one area at a time and see if the problem gets better. if it does in a certian spot thats the gasket that needs replaced. the most common is the throttle body gasket. Hope that info helps.
Old Oct 11, 2008 | 07:27 PM
Default Re: (bunnyhatch93)
speaking of which... i need to change out my throttle body gasket
Old Oct 12, 2008 | 08:36 AM
hastingsr's Avatar
i checked it and it seems to be showing two codes i think, 41-o2 sensor heater, and 43-fuel supply system
Old Oct 12, 2008 | 10:33 AM
start with replaceing the o2 sensor and go from there
Old Oct 12, 2008 | 11:37 AM
hastingsr's Avatar
took it to a friend thats a honda technition and he said it shouldnt be the o2 sensor he looked over the whole car and says the only thing he can think of is I probly have a bad gasket somewere
Old Oct 12, 2008 | 11:17 PM
does anyone think a bad alternator will affect the idle? reason i ask is because I think I have a failing alternator and a little ilde problem too
Old Oct 15, 2008 | 11:49 AM
sh4mr0ck's Avatar
Default Re: (vietnamezerice)
Yes, a bad alternator would mean a fluctuation in battery power and your car would struggle to stay running
Old Oct 15, 2008 | 10:05 PM
Default Re: (sh4mr0ck)
hmm... thanks for the info i think that might be why I have a bad idle... reason I say my alternator is bad is because my lights (cluster and headlights) flicker and/or dim at different loads or rpms
Old Oct 16, 2008 | 12:34 AM
gtec8285's Avatar
check your aicv and if aiint it check your fitv. the spring in it might be loose search on here you will find alot since this a common problem with honda motor
janek
Jun 25, 2010 11:39 AM
Si_chRis
Dec 25, 2008 08:52 AM
halfNhalf-83
Nov 20, 2003 11:12 PM
