H&R Sport Springs on G3-Teg Owners read...
Old Jul 27, 2002 | 05:11 PM
Understeer's Avatar
Default H&R Sport Springs on G3-Teg Owners read...
I'm lowered on H&R Sport springs. Now are you using a camber kit? Do I even need a camber kit when I lowered it 1.8"(f) and 1.5"(r)?
What will an alignment do? I know you can't correct camber on hondas without a camber kit,but will it help any?
Old Jul 27, 2002 | 05:39 PM
Jamison's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (Fj)
i had heard that an all wheel alignment will fix any problems, but im not sure. i have dropped my car on 2 differant suspension setups, and still havent gotten my wheel alignment done. it pulls to the right realllll hard...heh
Old Jul 27, 2002 | 06:02 PM
DuNkiN's Avatar
New User
im using those and i have a progress camber kit and the washer trick on the rear. an alignment with just fix the toe....and maybe the caster, but im not sure on that one
Old Jul 27, 2002 | 08:15 PM
neo1z's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (DuNkiN)
alignment will not fix camber, and you will need a kit. my kumhos are only 6 mos old and are dying
Old Jul 27, 2002 | 09:19 PM
Lonerider's Avatar
an alighnment will help with the toe
as for a camber kit....if u don't have the $$ to get one yet u should be fine after the alignment if u keep the tires rotated regularly.
Old Jul 27, 2002 | 09:29 PM
Erik95LS's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (Lonerider)
yep you will definatly need a camber kit of some sort. I went with the skunk.
Old Jul 27, 2002 | 09:56 PM
fiebru1119's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (neo1z)
yep you'll need a camver kit.. my dunlops are almost dead as well
Old Jul 27, 2002 | 10:25 PM
Understeer's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (fiebru1119)
I'm only dropped on sport springs, do I really need a camber kit?
Old Jul 28, 2002 | 10:38 AM
mugenracer's Avatar
i have a 1.5" drop all round and my tyres wear badly on the inside, i havent got round to get a camber kit yet, so as you have a 1.8/1.5" drop it would be worth your while getting a camber kit unless you dont mind shredding the inside of your tyres in less then 6k miles
Old Jul 28, 2002 | 10:45 AM
jeebusm3's Avatar
Default Re: H&R Sport Springs on G3-Teg Owners read... (mugenracer)
I have between a 1.75 and 2 inch drop in front and 1.7 in rear or so. I haven't gotten a camber kit and my fronts are wearing in the in the inner part but the rear is absolutely perfect. I rotate every 3k and it looks like I'll get at least 10-12k on these kumhos...
Old Jul 28, 2002 | 02:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: H&R Sport Springs on G3-Teg Owners read... (gtravsr)
You guys must not have gotten that toe-in set very well. I've had my H&R Sport springs w/ extra 1/2" lowering in back from the Koni shocks since February (about 12K miles now). I had the toe-in set to exact factory specs. I have over 2 deg. neg. camber all around and no camber kit, but my tires are still even all the way across after 12K miles. I rotate every 4K-5K miles.
This is how my front left tire looked from about 2 weeks ago.
[Modified by PatrickGSR94, 5:46 PM 7/28/2002]
JDM_nUt
Feb 17, 2010 10:33 PM
nismo350z
Jun 13, 2006 04:42 PM
00-0258
Jun 18, 2003 09:19 AM
4DoorLS
Aug 22, 2002 08:10 PM
GasHuffer
Aug 1, 2002 03:02 AM
