How do you get your window regulator handles off?
Serious question, those things so far are beating me 13 to 0.
What tool do you use? Is there a specific one? If so I will buy that sunofa-bitch.
the best way to do it is get a thin cloth like a shirt bottom or a shop rag. take the end of the reg put it between the handle and the panel and move it back and forhth like you milking a cow.and it will pop right off
depends which way the wire clip is facing. turn the crank to look at the open spot under the handle.
the clip is kinda "U" shaped.
if you see the top ends, then push them forward with a screwdriver.
if you see the bottom of the U, then pry it out with a hook tool or a skinny screwdriver.
