Abnormal rocker pad and cam lobe wear on euroR H22 with JUN III
Old Oct 5, 2008 | 09:34 AM
igrek's Avatar
Default Abnormal rocker pad and cam lobe wear on euroR H22 with JUN III
Less than 1000mi ago I installed JUN III camshafts and valve springs. Took them off to lock the rockers to degree them (didn't have a degree kit when were installing the cams).
So one of the rockers and one cam lobe has an abnormal wear.
What could cause this kind of wear? Was it an imperfection on the cam and it will eventually smooth out? I'm considering buying a set of new rockers but I'm afraid the new rocker will be damaged the same way.
Would appreciate any advices on what to do.
The pictures with larger resolution are here http://picasaweb.google.com/igrekster/RockerWear#
Old Oct 5, 2008 | 09:53 AM
IntegraType-R's Avatar
Usually seems like a oiling problem.. Most cams/ rockers will show some type of wear after awhile.. specially bigger cams, that have a strong valvetrain behind them.
This looks like a oiling issuse tho, that or these cams were just slapping the pads due to a looser then normal valvelash.
Old Oct 5, 2008 | 10:04 AM
logg_frogg's Avatar
Default Re: (IntegraType-R)
I agree that it looks like a possible oiling issue
Old Oct 5, 2008 | 10:31 AM
igrek's Avatar
I use Motul 300V 5w30. And this happened to the exhaust rocker of cylinder #1 (for what it matters).
Oiling issue means I have to check my oil pressure and clean the oil passages and orifices?
Old Oct 5, 2008 | 10:50 AM
Default Re: (igrek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igrek &raquo;</TD></TR><TR><TD CLASS="quote">I use Motul 300V 5w30. And this happened to the exhaust rocker of cylinder #1 (for what it matters).
Oiling issue means I have to check my oil pressure and clean the oil passages and orifices?</TD></TR></TABLE>
I'd start there.. what kind of oil pressure are u having at idle?
Old Oct 5, 2008 | 10:53 AM
Combustion Contraption's Avatar
Default FV-QR
Motul 300v 5w-30 can hurt you.
Is this a street car?
Old Oct 5, 2008 | 10:54 AM
igrek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">I'd start there.. what kind of oil pressure are u having at idle?</TD></TR></TABLE>
To be honest I have not checked it. Will do once I assemble everything. The oil lamp is turned off right after I start the engine. And it does not blink on idle.
Modified by igrek at 11:00 PM 10/5/2008
Old Oct 5, 2008 | 11:04 AM
DonF's Avatar
Default Re: (igrek)
It looks like used rockers. How many miles on the rockers?
Old Oct 5, 2008 | 11:08 AM
igrek's Avatar
Default Re: FV-QR (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">Motul 300v 5w-30 can hurt you.
Is this a street car?</TD></TR></TABLE>
Yes, it's a street car with a few bolt-ons. I'm going to switch to 5w-40.
Old Oct 5, 2008 | 11:11 AM
igrek's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">It looks like used rockers. How many miles on the rockers? </TD></TR></TABLE>
The rockers have 35000 miles on them. Was that a mistake not changing the rockers along with cams?
Old Oct 5, 2008 | 11:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (igrek)
if this problem was an oiling issue, many of us would have figured that out by now.
It happened to me with crower cams using amsoil and a few other h22 guys on the forum.
Seems like you caught it before any horrible damage was done.
Old Oct 5, 2008 | 11:36 AM
igrek's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">if this problem was an oiling issue, many of us would have figured that out by now.
Seems like you caught it before any horrible damage was done.</TD></TR></TABLE>
Yes, I'm aware of the problem with "eaten" exhaust rockers. But I did not find any solutions to the problem. The only reason I'm asking is I have only one rocker damaged. So I thought it is not related.
Old Oct 5, 2008 | 11:38 AM
98vtec's Avatar
moderator emeritus
Default Re: (igrek)
make sure your LMA on that rocker depresses correctly without sticking.
does the euroR have hydraulic or spring based LMAs?
Old Oct 5, 2008 | 11:46 AM
igrek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">make sure your LMA on that rocker depresses correctly without sticking.
does the euroR have hydraulic or spring based LMAs?</TD></TR></TABLE>
It has spring based LMAs. I did not notice any sticking. One question though - should I be able to depress the LMA further when it is fully depressed by the lobe?
Modified by igrek at 11:51 PM 10/5/2008
Old Oct 5, 2008 | 11:48 AM
98vtec's Avatar
moderator emeritus
Default Re: (igrek)
I've just never understood how this happens, indefinitely. I dont think anyone is ever going to be able to pin it to one thing.
"soft" rockers, thin friction pads, bad metallurgy, oiling...the list goes on.
IIRC, doesnt JUN use Honda cores?
Old Oct 5, 2008 | 11:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">I've just never understood how this happens, indefinitely. I dont think anyone is ever going to be able to pin it to one thing.
IIRC, doesnt JUN use Honda cores?</TD></TR></TABLE>
from what i've always knew, both spoon and jun use honda cores.
Old Oct 8, 2008 | 06:33 AM
igrek's Avatar
There are two part numbers for H22A rockers. One is for older H22A (A2) and another for the newer (A5,A5,A7,A8):
14620-P13-000
14620-P5M-000
Does anybody know what is the difference?
Is there a statistics which one tends to abnormal wear?
Old Oct 8, 2008 | 07:59 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes, it's a street car with a few bolt-ons. I'm going to switch to 5w-40.</TD></TR></TABLE>
Do you track this car?? If not then there is no need to switch to 40. Try using 0w-30. And a good synthetic oil (your choice).
Old Oct 8, 2008 | 08:17 AM
igrek's Avatar
Default Re: (DCFIVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFIVER &raquo;</TD></TR><TR><TD CLASS="quote">
Do you track this car?? If not then there is no need to switch to 40. Try using 0w-30. And a good synthetic oil (your choice). </TD></TR></TABLE>
One of the causes of the abnormal wear could be a weak oil film which could not withstand stiffer valve springs. To my understanding 5w-40 has "stronger" oil film so I would like to try it.
Old Oct 8, 2008 | 09:07 AM
98vtec's Avatar
moderator emeritus
Default Re: (igrek)
add zddp
Old Oct 8, 2008 | 09:24 AM
igrek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">add zddp</TD></TR></TABLE>
I doubt I can find it in Russia and I'm not sure if liquids are allowed to be shipped by ordinary shipping.
A Blue Lude
102
Oct 19, 2009 08:10 AM
" BRANDON HiCKS "
Jun 8, 2005 09:02 PM
canuck-mx6
Dec 4, 2002 07:58 AM
canuck-mx6
May 22, 2002 03:18 AM
