a couple crx questions
Old Oct 5, 2008 | 06:24 AM
djxtc65's Avatar
Default a couple crx questions
i just picked up a 89 crx with a b16 and ys1 and some crazy coil over set up the car runs strong but the body is just shot so im thinking of swaping everything into an ef hatch so my 1st ? is does all Suspension swap over it has the coil overs sk2 lcas and a sway bar
and does the dash go swap into a hatch i love the crx dash
and my most importent ? is can i use any b oilpan work on a b16 cause my oil pan is beat from the past owner from his turbo set up
Old Oct 5, 2008 | 08:09 AM
zrickety's Avatar
Default Re: a couple crx questions (djxtc65)
i have seen everything you mentioned done...the dash can be swapped with a little work. search on here and you should find most of it bolts straight up. not sure on the oil pan tho...think you might need the b16 one
Old Oct 5, 2008 | 11:59 AM
Redline130's Avatar
You will need to use either a B16 or a LS oil pan. A GS-R pan is different.
Old Oct 5, 2008 | 12:43 PM
djxtc65's Avatar
Default Re: a couple crx questions (Redline130)
i searched the dash swap and i only saw crx into 4d but im sure its ez to do
thanks for the info on the oil pan
one more question on the crx my sun roof does not close all the way any tricks or hints
Old Oct 5, 2008 | 01:19 PM
redsi89's Avatar
did you try and close it manually? your motor might be shot
Old Oct 5, 2008 | 01:33 PM
CRX Toad's Avatar
What is the coil over setup. If it looks crazy it might be an old Carrera inverted setup. Very cool and very pricey.
Old Oct 5, 2008 | 01:39 PM
djxtc65's Avatar
Default Re: a couple crx questions (CRX Toad)
the sun roof opens and closes it just doesnt shut on the pas side it doesnt fold down i guess you could say
and as for the coil over set up idk what brand it is yet i have yet to pull the tires off yet i plan on doin that tomorrow
and after lookin at it today i think i might have a diffent brake set up than stock the calipers look huge and brand new
MEBHB91
Mar 22, 2009 04:37 PM
MJobe
Nov 1, 2006 07:32 PM
emwavey
Nov 22, 2004 04:55 PM
curiousgpnoy
22
Jan 29, 2003 08:00 AM
