crooked wheel?
I recently got a 92 hatch and I noticed that the rear wheel was tured into the wheel well pretty badly. Can someone tell me what could be the cause of this... I cant really explain what it looks like...i will get some better pix later. Would I need an allignment, camber kit, or is something broken or bent? I just lowered it on Tokicos with h&r springs.
Modified by zbra09 at 7:04 AM 10/5/2008
that would be negative camber. You can either just get the car aligned and have the toe fixed, or you can get a camber kit and have the toe and camber set back to factory, whatever helps you sleep at night. But with proper toe, camber won't really affect your tire wear.
*edit: does it look like the rear wheel in this pic?
If so, it's camber.
If so, it's camber.
yea, i think im just going to get it alligned cause i need it anyways since i just lowered it. but the wierd thing is that its just the one wheel that got really bad, the rest seem to be fine even tho they probably arent
4serioferio
22
Mar 14, 2009 08:22 PM
osbornsm
Aug 31, 2002 09:20 AM
GoLowDrew
Mar 25, 2002 09:02 AM
