1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED
Old Oct 5, 2008 | 12:54 AM
doughboi904's Avatar
Default 1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED
AS U ALL NO I POSTED ABOUT A PROBLEM...
well the car was over heating replaced thermostat and it ran fine...last night i was riding home and its started jerking and the rpms kept jumping... and just turned off... had to push it all the way home... today the car wont start for nothing... lights and everything turns on but wont start.. i tried to push start it also(cuz its a 5spd) but no help... called autozone and said could be several things but never named em and said he can test my alternator if i brought it up there..BUT ALL MY LIGHTS AND **** WORK..... does anyone know what the hell it could be???... i could lose my job over this p.o.s help me asap!!! ....
WELL I GOT SOME MORE INFO AND A VID TO HELP OUT....I GOT NEW RELAY..DIDNT PHASE IT... CHECK OUT THE VID SEE IF U CAN TELL WHAT IT IS BY THE SOUND...
http://www.youtube.com/watch?v=Nwe43QxfaRI
Modified by doughboi904 at 2:04 AM 10/5/2008
Old Oct 5, 2008 | 04:05 AM
conker's Avatar
Default Re: 1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED (doughboi904)
My igniter went out at about 250k. It did not give any warning like your car did, however, just died. It would crank and everthing worked, no spark, no go. MSN lists it as a common failure in our cars.
http://autos.msn.com/research/...ccord
May want to look into.
Old Oct 5, 2008 | 07:49 AM
AccordEX1991's Avatar
Default Re: 1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED (conker)
You have to go through the no start troubleshooting process to find out what is missing. Spark, fuel or compression. But most likely a no spark issue.
A no spark issue could be the igniter, distributor sensors or the ignition coil but you have to test one at a time to avoid spending on unnecessary parts. Or you can just get a rebuilt distributor assembly.
Old Oct 5, 2008 | 02:51 PM
hon2984's Avatar
Default Re: 1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED (AccordEX1991)
to me it sounds like you dont have any compression. i would check compression!
when it got hot it could have warped the head, or blew the gasket.
Old Jul 17, 2009 | 09:11 AM
firefighter2461's Avatar
New User
Icon7 Re: 1992 HONDA ACCORD LX STARTING PROBLEM..CONTINUED
Try checking your main relay. Located high under the dash. I have a 92 Accord EX and I had the same problem. So frustrating! I watched the video, and it sounds like the same problem I had. I tested the ignitor coil and it ohmed bad (replaced it). All other starting components were fine. But when I started reading other forums about the main relay over and over again I decided to make the effort!! Was well worth it!! Try the URL at the bottom of my reply it'll walk you through all the steps! Hope it works out for you!! Also, I took a large magnifying glass and you could see the cracks at the solder joints! Just look REALLY close at each joint and all around it! I almost missed a cracked joint. Have had zero problems since the fix!http://techauto.te.funpic.org/mainrelaydefine.php
clifftbrd
Jul 11, 2014 01:40 PM
vetalk90
Jun 27, 2012 04:22 PM
hamelc1
Apr 10, 2010 04:43 AM
doughboi904
Oct 3, 2008 11:25 AM
chilihotorcold
May 25, 2007 08:41 AM
